It is currently Dec Tue 10, 2019 1:16 am
 Post subject: Using the PHONO input on the RCA 14X
PostPosted: Jun Tue 18, 2019 3:40 pm
Recapped an RCA 14X and it's one awesome radio. I am north of Boston and 1010WINS came in clear as a bell last night, even with local WBZ 1030 almost on top of them. Even the shortwave sounds great.
Question: There's no switch to select PHONO input (showing a picture of the back of the rig.) I don't see an explanation in the schematic, does anyone know how PHONO was supposed to operate?
 Post subject: Re: Using the PHONO input on the RCA 14X
PostPosted: Jun Tue 18, 2019 4:17 pm
As there is no Phono switch to cut out the radio, you may have to find a quiet spot on the dial!
oh... on some sets, you also have to open the antenna jumper.
If I'm not mistaken, 14X does not have one... :)
PostPosted: Jun Tue 18, 2019 6:28 pm
yes, other have suggested the quiet spot on the dial. But your "jumper" statement gives me an idea, since there is a screw next to the phono jack for an antenna, I wonder if there's a connection (no pun intended.)
Absent a users manual I'll have to do some experimenting.
PostPosted: Jun Tue 18, 2019 7:07 pm
As I'm sure you already know, the single antenna connection on the rear is for a long wire (outdoor antenna) for reception of the Short Wave band.
With it disconnected or unused, switch to Short Wave and tune to a noise free spot when using the Phono input.
14X image: • http://blogs.creighton.edu/cjw84423/fil ... GP6349.jpg
14X image: • http://blogs.creighton.edu/cjw84423/fil ... GP6351.jpg
fyi... RCA 15X has a jumper. lol
image: • http://capeoldradio.com/cor_picts/RCA%2 ... 553-P4.jpg
PostPosted: Jun Tue 18, 2019 7:22 pm
Yep, disconnect the antenna. Or, if you don't use the shortwave feature, you could probably disconnect one of the wires from the SW band switch and disable reception when the switch is in the SW position. Honestly, I don't know why they did not just put another position on the band switch to disable the radio and apply phono signals. As it is, you will get audio mix from the phono and radio. I thought RCA had some sharper designers than that. Actually it appears that if you could move the bandswitch stop detents to allow the rotary contacts to go one more position to the left, they would be away from the stationary contacts and kill radio.
PostPosted: Jun Tue 18, 2019 9:54 pm
Thanks, everyone. I already have a couple of floor models with phono inputs - and a switch to select it. This was just a curiosity to me why there isn't a switch on the 14x. Yea, I agree, thought the RCA guys had more on the ball. I'll play with it and report back on where/how to listen to something using the phono.
PostPosted: Jun Wed 19, 2019 3:58 am
The phono input is after the volume control. The phono accessory probably has it's own volume control. Just turn down the control on the radio.
Probably a "feature" to encourage buying the correct phono.
Bob
Life is too short to be serious all the time.
PostPosted: Jun Wed 19, 2019 2:00 pm
So here's the answer. It's not a shorting jack you simply find a spot on the dial where there's no radio broadcast. There is no volume control for the phono input. I agree with "Elvira" that the RCA designers wanted you to buy their phonograph. Or maybe they decided everybody liked their music at the same level. :D
At least I can control the volume of my iPhone. Not a big deal I wasn't planning on using it, just was curious the how and why.
Thanks, everyone!
Post New Topic Post Reply  [ 8 posts ]  Moderator: sofaslug
Users browsing this forum: Koby, ReimaginedbyLynn, rugged and 17 guests
