It is currently Oct Sun 20, 2019 9:46 am
 Post subject: Canadian fada c75a info needed
PostPosted: Jun Wed 19, 2019 11:27 pm
Hi Members. A good buddie just gave me a 1924 fada radio.no power supply, tubes or speaker.im looking for any info on this gear.i worked on many gear including radios for over 40 years but this is the oldest radio I have seen.i hear it's the same as a 175a? Thanks,RonL
Caretaker of Farnsworth 651p and Rca ctc5 TVs.a source of vintage canadian tv service data
 Post subject: Re: Canadian fada c75a info needed
PostPosted: Jun Thu 20, 2019 7:16 am
Is it this one? :arrow: http://www.nostalgiaair.org/pagesbymodel/888/M0028888.pdf
BTW, I don't know why they drew the 81 rectifier as a dual-diode tube when it's only a single-section rectifier.
PostPosted: Jun Mon 24, 2019 12:15 pm
Thanks Steve but I'm not sure if it's close enough? Any chance I could get some advice from other veteran radio members? I figure there be lots here?I might be out of my depth here being I have never worked on gear this old.some components I don't recognize.not sure what is the best way to disassemble so I can get a good look at the underside.how difficult is it to get a output transformer/speaker? I think I can figure out a dyi power suppy.any help would be appreciated. This 95 year old radio deserves to live again.RonL
PostPosted: Jun Mon 24, 2019 11:01 pm
First check the 210 tubes. If they are no good, you might consider buying a 'parts'
Philco 20 and lifting speaker, power, and output transformer.
The 210 are worth their weight in gold and they have 7 volt filaments.
Otherwise the Philco 20 tubes are the same as your radio.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jun Tue 25, 2019 9:43 pm
Does your radio look like this. The schematic on Rider Page 1-28 may work.
Ed.
PostPosted: Jun Fri 28, 2019 7:16 am
Hi Ed-that is my radio.any idea where i can find Rider Page 1-28?
Hi Steve Dow. at this point,i don't know what tubes this set takes.not marked and no tubes.
Thanks to both of you.
RonL
PostPosted: Jun Fri 28, 2019 7:58 am
The page you seek :arrow: http://www.nostalgiaair.org/pagesbymodel/731/M0039731.pdf
The photo Ed posted is of a 192 Neutrodyne. It was powered by storage batteries and could work with a variety of detached speakers, like these:
:arrow: https://radioatticarchives.com/radio.htm?radio=1048
:arrow: https://radioatticarchives.com/radio.htm?radio=5293
:arrow: https://radioatticarchives.com/radio.htm?radio=5295
Last edited by Steven in Oregon on Jun Fri 28, 2019 8:10 am, edited 1 time in total.
PostPosted: Jun Fri 28, 2019 8:09 am
Thanks Steve.this will help. RonL
Post New Topic Post Reply  [ 8 posts ]  Moderator: sofaslug
Users browsing this forum: andyjon100, Google [Bot], Squelch88 and 10 guests
