Antique Radio Forums
https://antiqueradios.com/forums/
RCA 6T restroration finished, a darn good radio!
https://antiqueradios.com/forums/viewtopic.php?f=1&t=362072
Page 1 of 1
Author:  LarryAD [ Jul Thu 18, 2019 2:43 pm ]
Post subject:  RCA 6T restroration finished, a darn good radio!
Picked up for $5, even at that price I bet most would pass on it. RCA radios are good performers and I think this cabinet is a good looker. I always start with the cabinet restoration first. The cabinet was easy to knock apart, the top piece of walnut was missing and the front walnut was missing quite a bit so I decided to replace the front piece. I used the inner piece of the front for maintaining the correct dimensions and added a 3/16 piece of plywood on the backside and two ply alwood walnut for the front. I chose a nice matched section from a 2X4 foot piece of walnut. I used Titebond wood glue and ironed the face and the top veneer, this process works well and is quicker than using contact cement. I have been using old fashioned joint compound for years as the wood filler. It is also quick and easy to use. For the walnut I used minwax English chestnut oil stain first and after twenty four hours I applied a coat of alcohol based Van Dyke brown aniline dye over the entire cabinet. The score marks were created using a Dremel tool with two round stones placed against a clamped piece of steel. I have two sealer coats sprayed, I'll add 3-4 top coats of clear semi-gloss lacquer in the next day or so.
Author:  voroush [ Jul Thu 18, 2019 10:42 pm ]
Post subject:  Re: RCA 6T restroration started
Definitely a labor of love, nice work! What do you use to color the joint compound prior to filling?
Author:  pauls.ironhorse [ Jul Thu 18, 2019 10:59 pm ]
Like to see what the chassis looks like.
Author:  LarryAD [ Jul Thu 18, 2019 11:17 pm ]
I apply the joint compound to the veneer let it dry, sand and then use oil based stain over the filled veneer.
Author:  LarryAD [ Jul Thu 18, 2019 11:45 pm ]
Here are pictures of the chassis and speaker. The voice coil is dragging a bit, may need to re-cone the speaker, the underneath side of the chassis is remarkably clean, the top side as seen has quite a bit of surface rust. I will remove the tuning capacitor and dial and bead blast and then clearcoat the chassis.
Author:  pauls.ironhorse [ Jul Fri 19, 2019 12:24 am ]
Thanks for the additional pics. Will be following this restoration.
Author:  LarryAD [ Jul Fri 19, 2019 11:10 pm ]
Bead blasted the chassis after removing the tuning gang and dial. Painted the transformer black and clear coated the chassis. The dial lens was very dark with dark spot so I decided to make a new one. Stay tuned for more updates.
Author:  mdnelson [ Jul Sat 20, 2019 4:52 pm ]
Looks great Larry! Nice work.
Author:  LarryAD [ Jul Mon 22, 2019 1:03 am ]
Post subject:  Re: RCA 6T restroration (cabinet finished)
A little more time spent on the RCA this weekend, made a plastic dial cover, couple of coats of sealer, four coats of semi-gloss clear and grill cloth salvaged from a console. The chassis has been recapped some of the rubber wire replaced, new gromets under the tuning gang, found the audio output transformer opened, it was potted in tar, used a butane torch to heat and removed the bad transformer. Bead blasted and clear coated the can. I'll stuff it will a good transformer next.
Author:  LarryAD [ Jul Thu 25, 2019 12:45 am ]
Post subject:  Re: RCA 6T restroration finished, a darn good radio!
Finished the RCA chassis and speaker restore and placed in back in the cabinet, IMHO the radio turned out well and is a good performer.
Author:  decojoe67 [ Jul Thu 25, 2019 1:19 am ]
Excellent work! Out of all the similar RCA tombstones, that particular model with the fluted pillars is my favorite. The repurposed grill cloth is a very nice touch. Enjoy that beauty!
Page 1 of 1 All times are UTC [ DST ]
