It is currently Nov Thu 26, 2020 1:58 pm
Post New Topic Post Reply  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: RCA Victor 110K
PostPosted: Oct Thu 29, 2020 3:11 am
I redid a RCA 19K, a very similar design, finished it a couple month ago. . Works great after a chassis rework. Be very careful replacing the chassis, it required pressure, due to the spring metal braces, to get it where it's supposed to be. I didn't have it completely lined up, and broke the dial glass. Radiodaze manufactures them, so will have to order one, $40 wasted due to stupidity.
Frank
PostPosted: Oct Thu 29, 2020 4:00 pm
Indiana Radios wrote:
Haggy38 wrote:
Thanks all you guys for the feedback, I ordered the correct ones, and thinking how in the hell Im going to get this horrible black knobs detach, they glued them with some type of epoxy :roll: .......
Simple, there's no reason to save or preserve those knobs so just get a large pair of pliers and crack them into little pieces and extract them that way. Just try not to scratch up the radio in the process. Once the knobs are off, then you can remove the chassis and clean or chip off the glue from the shafts. It's no big deal, you just need to use a little patients.
It’s going to be tight and precise operation and not scratching this beautiful wood :shock:
Gustavo
PostPosted: Oct Thu 29, 2020 4:27 pm
Frank
Hi Frank,
Sorry to hear that, in this vintage apparatus all details counts I guess. I need to pull out the chasis and start changing paper caps, but I need some assistance regarding the type of caps or where should I get them. Thanks.
Gustavo
PostPosted: Oct Fri 30, 2020 4:03 am
OK, here's another idea. Get a soldering iron and carefully melt away the plastic center of each knob until they become loose and slide off. I suggest you do this in a well ventilated area.
Michael Feldt
www.indianaradios.com
PostPosted: Nov Sun 01, 2020 3:19 am
Thanks, it seems a good plan, as soon I get the replacements, the operation will start.
Gustavo
PostPosted: Nov Sun 01, 2020 3:35 am
Hello Gustavo
I love everything about this restoration: beautiful Deco radio, adventure, great condition, and wonderful history. You're doing a good thing preserving it!
Charles
PostPosted: Nov Wed 18, 2020 1:10 am
Hi guys,
After long wait the original knobs are here in Bogotá, after very careful operation I was able to pull out this horrible knobs, pretty happy with the result, now recap is coming!!
Gustavo
PostPosted: Nov Wed 18, 2020 5:50 am
VanEpsFan1914 wrote:
Hello Gustavo
Charles
Hi Charles,
I really appreciate your comments, I agreed this radio combines lots of history and preservation. Thanks.
Gustavo
Post New Topic Post Reply  [ 28 posts ]  Moderator: sofaslug Go to page Previous  1, 2
Users browsing this forum: No registered users and 39 guests
