It is currently Nov Thu 26, 2020 2:27 pm
 Post subject: RCA victor 56x reception.
PostPosted: Oct Sat 24, 2020 2:35 am
About a week ago I found an RCA 56x at the dump. I brought it home, plugged it in, and listened to the loud hum. I figured I would replace the electrolytic capacitors. Well that helped but I wasn’t getting any stations. So I replaced all the other capacitors in the radio. Now I can get a couple of stations but they are faint. The resistors are a little off but not too bad. So what are your recommendations as to what to do next to improve the reception?
 Post subject: Re: RCA victor 56x reception.
PostPosted: Oct Sat 24, 2020 4:47 am
Were you able to test the tubes? They can be very weak, and add to the problem. Have you worked on sets before?
PostPosted: Oct Sat 24, 2020 1:33 pm
No, I have not tested the tubes. Some of them glow. There are two black colored tubes that get warm but I can’t see if they are functioning. This is the first radio I have worked on. So, how do I go about testing the tubes or should I just get new tubes.
PostPosted: Oct Mon 26, 2020 3:54 pm
Do you have a tube tester?
PostPosted: Oct Mon 26, 2020 4:19 pm
You could buy an entire set of all 6 tubes, used and tested good, from findatube.com for $14+S&H.
Rodney -- KG7EPW
PostPosted: Oct Mon 26, 2020 4:23 pm
The tube heaters on that radio are connected in series, so unless there is a short somewhere in the wiring, if one tube is heating, all the others are as well. Reception could be weak because of any of numerous factors. There could be a weak tube or two, resistors out of tolerance or poor IF or RF alignment. I always clean the tube pins and tighten up the sockets to make sure that the tube pins are making good electrical contact in the sockets.
PostPosted: Nov Tue 24, 2020 2:25 pm
I bought a whole new set of tubes, but as far as I can tell, it’s made absolutely no difference. I’m wondering about the wire coming out of the back of the radio. I’ve been assuming it is a ground wire, but it makes no difference to the reception if I connect it to a ground. Is my assumption wrong?
PostPosted: Nov Tue 24, 2020 3:10 pm
56X requires the loop antenna that came with it.
Caterva carissima mea est Cimictus. Dan B
PostPosted: Nov Tue 24, 2020 5:50 pm
Yes the loop antenna is still with the set.
PostPosted: Nov Tue 24, 2020 6:16 pm
That wire in the back might be o extend the antenna for the short
wave band. Try a short length of wire on it and see if reception
improves. Otherwise trace it out and see where it goes. Its not
a ground..
PostPosted: Nov Tue 24, 2020 11:10 pm
The black wire hanging out is the SW antenna.
Did you remove the antenna wires when you replaced parts?
Did you try the SW band? I can get 3 strong Spanish stations in Florida
Do you have a schematic?
This is my 56X5 radio and you can verify your wiring is the same.
It may just need an alignment OR a cap was soldered to a wrong pin. For that, you will need to compare each part replaced with the schematic.
You will find this to be a fine playing radio once you get it working.
Freeman
Post New Topic Post Reply  [ 11 posts ]  Moderator: sofaslug
Users browsing this forum: Steve Chambers and 36 guests
