It is currently Nov Thu 26, 2020 2:02 pm
 Post subject: Columbia 360 Hatbox HELP!
PostPosted: Oct Wed 28, 2020 7:19 pm
Hi guys!
I recently got a BEAUTIFUL Columbia 360 phono and I'm in love with it.
I already put a lot of work in (replaces stylus, soldered wires, cleaned, sprayed etc) and I can't wrap my head around the reason why she's humming and the sound is not what it should be. I connected an external speaker via 1/4' cable and still no good :(
When I touch the 1/4' output jack the humming gets a little better. but more than anything, I'd like a clean output source to external speakers...
THOUGHTS?
Thanks so much!
Koala
 Post subject: Re: Columbia 360 Hatbox HELP!
PostPosted: Oct Wed 28, 2020 10:36 pm
Hi there-- You mention soldering wires but you don't mention replacing the electrolytic capacitors. There are some capacitors in old tube gear that go bad with time, and should always be replaced--the "hum" is 60hz line voltage humming, and your filter capacitors are supposed to get that out. Bad caps=bad sound quality.
I'm sure it will be a fine phonograph when you are finished, though. Can you post some pictures to show it off a little? All my phonographs are the old-fashioned sort with cranks, and if I want to see electric ones, I have to look at other peoples' restorations.
PostPosted: Oct Thu 29, 2020 10:38 pm
Thanks VanEpsFan1914! Replacing caps is something I’ve never done so I’m gonna do some research and see if I’m ready for that :wink:
Posting some pics!
PostPosted: Oct Fri 30, 2020 6:11 am
The thing to remember about electrolytic capacitors is that they are polarized components. One lead is negative and the other positive. If you hook them up backward they will literally explode (with a loud and smelly bang than can send shrapnel around the room).
It's important to figure out how the caps are marked (usually an arrow points at the negative lead) and how they're shown on schematics (usually the curved side is the negative side), in order to get them installed correctly.
Rodney -- KG7EPW
PostPosted: Oct Fri 30, 2020 4:10 pm
Welcome to the Phono Forum at ARF.
The Columbia model number and sometimes a circuit
schematic sticker was glued on underneath the cabinet.
Take a look there and post a photo of the label
if there is one.
There were several different amps for the Columbia 360s,
with different tube complements.
Some were push-pull, and others more simple SE.
Also recommend all wax coated paper capacitors
changed out, not just the electrolytics.
We have the circuit schematic for you,
when we know which amp you have in the 360.
Hotwax
Plus your capacitor tutorial:
http://www.wjoe.com/capacitorinfo.htm
PostPosted: Oct Fri 30, 2020 4:37 pm
Just to chime in here, these are the electrolytics that are most certianly bad as they look original.
If you need help you will get step by step help here on ARF to replace these. The wax caps (small brown tubes) may need replacing also but maybe later.
If you do decide to do this yourself you will need to remove the chassis and provide better picture of the underside (and top side) of the chassis.
Just a suggestion, edit your profile to show your location (city/state) and sometimes help or offers is next door to you.
Users browsing this forum: No registered users and 16 guests
