It is currently Nov Sun 28, 2021 5:51 pm
Post New Topic Post Reply  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: 6 Volt Car Radio, worth saving?
PostPosted: Apr Sun 04, 2021 5:08 pm
Present from auction house owner.
Doesn't look like made to fit in dash.
What do I need to test/operate this?
"Invisible airwaves crackle with life
Bright antenna bristle with the energy"
 Post subject: Re: 6 Volt Car Radio, worth saving?
PostPosted: Apr Sun 04, 2021 5:30 pm
It will run off a 6 volt DC power supply capable of providing about 10 amps under load.
There's really no interest at all in aftermarket car radios like that one. They do usually work fairly well with a good enough antenna. Some people used to convert them to run on AC power and listen to them in the house or garage. But they have pretty close to zero value, which explains why that one was given to you.
People who own collector cars only want the OEM factory radios for their vehicles, and usually have a spare one already.
PostPosted: Apr Sun 04, 2021 6:54 pm
Have you had it opened up? If it's all there, would you consider selling it? P.M. me if so, thanks,Perry
I love the smell of Bakelite in the morning....
PostPosted: Apr Sun 04, 2021 7:23 pm
I actually still use a re-purposed car radio in the bathroom, but not a vintage tube unit like this! It's a [EDIT]1980 factory s/s radio from a [EDIT] 1980 Honda Accord (long sold!)... I replaced the radio in it with a high-end after-market unit ([EDIT] Blaupunkt)
The bathroom radio runs off a 14 VDC (from 120 VAC) P/S and feeds a Koss M65 Plus speaker... sounds very good!
If I had your tube radio, I would likely restore it for workshop use.
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Apr Sun 04, 2021 7:52 pm
The Automatic Radio model D-200 is a car radio for Dodge and Plymouth 1949-1950.
https://www.radiomuseum.org/r/automatic ... _1950.html
I don't remember how they looked in the car.
I do remember the sign a repair shop owner made after working on a 1949 Dodge.
It said "We don't know a d*** thing about Dodges."
Jay
PostPosted: Apr Sun 04, 2021 7:53 pm
yummy yummy... lemon cake.
:) Greg.
PostPosted: Apr Sun 04, 2021 8:07 pm
I had a 1950 Plymouth club coupe. Lost it in a divorce settlement, oh well....it didn't have a radio, but I can see how it would fit.
PostPosted: Apr Sun 04, 2021 10:01 pm
Will do!
Thanks!
PostPosted: Apr Sun 04, 2021 10:03 pm
:) Greg.
You spotted that!
Yes, it was delish! :D
PostPosted: Apr Sun 04, 2021 10:05 pm
engineer wrote:
I actually still use a re-purposed car radio in the bathroom, but not a vintage tube unit like this! It is a 1970's factory s/s radio from a Honda Accord (long sold!)... I replaced the radio in it with a high-end after-market unit (brand forgotten!)
Cheers,
Roger
Thanks, Roger!
PostPosted: Apr Sun 04, 2021 10:07 pm
Jay
Thanks, Jay!
The auctioneer did say it was from Plymouth.
PostPosted: Apr Sun 04, 2021 10:09 pm
Yes, it is from a Plymouth.
PostPosted: Apr Sun 04, 2021 11:01 pm
Are you sure about that current requirement? Some years back I had a more recent tube car radio that worked fine in the house on a 12 volt/2 amp transformer.
PostPosted: Apr Sun 04, 2021 11:17 pm
The radio specifies 6 volts on the label.
PostPosted: Apr Sun 04, 2021 11:22 pm
Right, it's an older radio than the one I had. At a point in time, car manufacturers changed from 6 to 12 volt ignition systems. My question was regarding current, not voltage. Amps, not volts.
PostPosted: Apr Mon 05, 2021 12:00 am
Sams Photofact in AR-2, shows rating of 5.4 amp at 6 volts.
EDIT: corrected spelling
Nick
vwradios.com
PostPosted: Apr Mon 05, 2021 12:56 am
fifties wrote:
Dalton wrote:
fifties wrote:
[quote="Mr
Got it.
PostPosted: Apr Mon 05, 2021 2:47 am
That radio just needs a bit of TLC and the chrome trim to perk it up to $350. :D
This car has the deletes in place of a radio, needs one.
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Apr Mon 05, 2021 10:04 am
Hey, that is exactly what my old Plymouth looked like, ok, to confuse things more for the discussion, I believe it was 6 volt, positive ground.
Post New Topic Post Reply  [ 27 posts ]  Moderator: sofaslug Go to page 1, 2  Next
Users browsing this forum: Geae_Liska and 45 guests
