It is currently Oct Thu 28, 2021 6:34 am
 Post subject: Help with Freed Eisemann
PostPosted: Sep Wed 08, 2021 12:32 pm
Hello,
I need help identifying this radio. The closest I’ve been able get is the Model FE-24A posted by Gregg two years ago. Attached are photos. I’m planning for retirement by gathering project radios, parts and schematics to keep my busy and my mind stimulated. You guys were a wealth of information for one of my first projects years ago, so here we go again.
 Post subject: Re: Help with Freed Eisemann
PostPosted: Sep Wed 08, 2021 2:51 pm
Your set is a superheterodyne while the FE-24A is a TRF set, not very close. You need to post the tube lineup of your set to help us ID what model you have.
Try FE-60: http://www.nostalgiaair.org/pagesbymode ... 006469.pdf
Michael Feldt
www.indianaradios.com
PostPosted: Sep Thu 09, 2021 1:59 am
Tube list. The metal can was rusted up with no visible markings. The other tube sockets actually had the tube type molded in them.
PostPosted: Sep Thu 09, 2021 2:17 am
The metal can is the ballast. On the schematic Michael linked to, it's shown as a K49C.
It's a socketed device, but it's not a vacuum tube... It's basically just a power resistor. It's designed to drop 49 volts at 300 mA, with a tap for a dial lamp.
Rodney -- KG7EPW
PostPosted: Sep Sat 18, 2021 5:11 pm
The FE-60 has a different tube layout. Does anyone else have any ideas or is this just that rare of a set? Thanks.
PostPosted: Sep Sat 18, 2021 10:19 pm
The model 357-L looks like the correct tube arrangement. I think the 357-P is the same.
https://www.radiomuseum.org/r/freed_eise_357l.html
Edit: It's probably a 357-P. I think the model L was for export to Europe.
https://www.radiomuseum.org/r/freed_eise_357p.html
Jay
PostPosted: Sep Tue 21, 2021 11:51 am
Thanks Jay. I downloaded a schematic from Steve Johnson’s website. The tube layout and type match up. I would love to find more info such as a Photofact, etc.
Leon…
Post New Topic Post Reply  [ 7 posts ]  Moderator: sofaslug
Users browsing this forum: dabcckoq549, ylr and 12 guests
