Antique Radio Forums
https://antiqueradios.com/forums/
NOS AK Breadboard/Cord?
https://antiqueradios.com/forums/viewtopic.php?f=1&t=402490
Page 1 of 1
Author:  Nuke [ Sep Tue 21, 2021 1:38 am ]
Post subject:  NOS AK Breadboard/Cord?
Greetings-
Picked up an Atwater Kent breadboard 10A model 4550 that had the end of the cord wrapped in a manner that looked like it could be factory. I've attached pictures below. I believe at least the cord could be new old stock. The only thing I was told was this was sitting in an attic for years and came with BB tipped 201a tubes that have good filaments. I will check audios and emissions later.
Author:  jclivenichols [ Sep Tue 21, 2021 2:27 am ]
Post subject:  Re: NOS AK Breadboard/Cord?
Could easily be the original, it looks just like the one on mine.
Author:  mrx [ Sep Tue 21, 2021 3:16 am ]
This looks like a Win Win,with good BBTT 01A's.The underside looks untouched,need pictures of the top.
Author:  Dave Slusarczyk [ Sep Wed 22, 2021 1:50 pm ]
Looks to be oroginal to me! Great find!
Author:  wiscojim [ Sep Wed 22, 2021 5:01 pm ]
If original, they did a crappy soldering job on it. My guess is not original.
Author:  atwaterkent1 [ Sep Thu 23, 2021 5:20 pm ]
Post a photo of the connections end of the cord, that would help.
Author:  Nuke [ Sep Fri 24, 2021 1:20 am ]
The problem is I would have to unwrap it. I am considering leaving it alone as proof it is NOS - at least the cord. Both audios are good so I believe it likely hasn't been used much - if at all. Its been stored in an attic so it has nearly 100 years of dirt and patina, but no real wear. The paint looks aged for sure. Unless I just unwrap a small piece at the end. Thinking about doing that because I am curious.
Author:  Nuke [ Sep Sun 26, 2021 12:00 am ]
Some more pictures
Author:  Dave Slusarczyk [ Sep Sun 26, 2021 4:33 am ]
Gorgeous!
Author:  jimmc [ Sep Sun 26, 2021 7:21 pm ]
If the cable has never been unwrapped I would expect a little yellow tag attached to the bloody end, secured with a knot on the tail of the outer braid.
My AK 10-C has the remains of such a tag and the picture I am attaching is from a virgin AK-20 installed in a cabinet and the label has rarely seen light of day.
This shows the correct battery voltages for the color of the wire in the cable.
Jim
Author:  Nuke [ Sep Sun 26, 2021 9:58 pm ]
Sounds like you have a rare virgin unit and you probably should hold on to it. I believe my radio's cord is at least NOS. There could be a tag wrapped underneath as I think the connecting wires are folded over and there is something around them. I'm tempted to at least cut off part of the wrap and see.
Page 1 of 1 All times are UTC [ DST ]
