It is currently Jan Fri 28, 2022 4:37 pm
 Post subject: Found in attic, Radiola V Model AR-885-A
PostPosted: Sep Tue 07, 2021 8:06 pm
Found the Radiola in my attic when preparing to move. Live in Reading Massachusetts and would rather not throw it in the trash. Happy to gift it to a local member.
 Post subject: Re: Found in attic, Radiola V Model AR-885-A
PostPosted: Sep Wed 08, 2021 5:17 pm
Someone needs to grab it.
Jeff
PostPosted: Sep Thu 09, 2021 2:22 am
I'd drive down to get it.
Sent an Email and did not receive a reply.
I am still interested.
PostPosted: Sep Fri 10, 2021 12:16 am
I'm in Connecticut. PM me if you want to get rid of it & JBL-1 can't make it there.
PostPosted: Sep Fri 10, 2021 11:12 am
Going down today.
PostPosted: Sep Fri 10, 2021 12:36 pm
What about the radio? Someone post pictures whoever gets it. Just to break hearts, if it is nice.
PostPosted: Sep Sat 11, 2021 3:00 am
Here's hoping JBL-1 got it.
PostPosted: Sep Tue 21, 2021 1:05 am
Here are some pictures of the Radiola V. I have a big dining room project going where I don't have the ceiling enclosed so I haven't had time to check the audio transformers. It was missing the tubes and the headphones may have been recently sent to the dump. It does have the wood top and is pretty clean. The crystal may work once the metal holder is straightened out. Glad to have this Radiola. I've never owned one of these.
PostPosted: Sep Tue 21, 2021 1:15 am
That is my favorite model of Radiola, unfortunately I haven't come across one yet...I'd say your luck was at a very high level, since you got the top! I understand they are even scarcer than the two radio chasses and bottom tray, and often the crystal apparatus is missing pieces as well. The action of the extended-range variable condenser is engaging to watch. Enjoy...I'm quite envious!
PostPosted: Sep Wed 22, 2021 2:05 pm
Fantastic!! Happy for you!! Plus the top!!
What a find!!
http://pages.suddenlink.net/davesradios/
PostPosted: Sep Thu 23, 2021 3:13 am
I have one of those and it plays well through a horn speaker with some 01A's although I believe it was made for 1 Amp tubes.
There should be some glass tube grid leaking resistors on each audio stage. There was also a long wave coil option although most were made for broadcast.
As I recall it will have a "C" battery connection on the side, I recommend using a C battery on this set.
Original top is worth the price of the set.
Jim
Post New Topic Post Reply  [ 11 posts ]  Moderator: sofaslug
Users browsing this forum: Ron Ramirez, westcoastjohn and 14 guests
