Wilcox Gay?
Share collecting tips/ideas, discuss antique radios and related items. Restoration topics should be put in that category; other topics that don't directly involve radio or radios also belong in other categories. Ads are not permitted.
Moderator: sofaslug
Post Reply
Jimradio
Jan Mon 11, 2016 12:19 pm
Spring Lake, MI USA
Wilcox Gay?
Post by Jimradio »
https://www.radiomuseum.org/r/wilcox_ga ... _wood.html" -="window.open(this.href);return false;
Hello Guys, I need more info on this radio, any help would be appreciated. I have this radio would like a schematic.
Jim KA8ZXJ
Spring Lake MI 49456
LarryFS
Aug Sat 08, 2015 8:50 pm
Fort Worth, TX
Re: Wilcox Gay?
Post by LarryFS »
Is there a model number? Can you post the tube lineup?
Jimradio
Spring Lake, MI USA
Re: Wilcox Gay?
Post by Jimradio »
Thanks Larry, can not find a model # this is the tube line up,5Y3, 6F6, 6Q7, 6K7, 6A8.
Jim KA8ZXJ
LarryFS
Fort Worth, TX
Re: Wilcox Gay?
Post by LarryFS »
I put the tube lineup into https://grillecloth.com/sylvania/tubelist.php and didn't get any listings for Wilcox Gay. That's a puzzle! Could one of the tubes be incorrect? Maybe a previous owner put one in that didn't belong. Maybe someone familiar with Wilcox Gay will chime in.
Added: I found a 12 Sep 2018 post by member bobwilson1977 that mentioned he restored one. Didn't list a model number.
Dale Saukerson
Jan Thu 01, 1970 12:00 am
Minneapolis, Minnesota
Re: Wilcox Gay?
Post by Dale Saukerson »
Does your set have an eye tube ?
The referenced pic seems so, but you did not list one in the tube lineup.
Subbing between 5y3 and 5z4 rectifier and including or excluding eye tube, I did some Riders searching in my database of Riders entries using the remainder of the tube lineup you gave.
Results:
6f6, 5y3, no eye, 27 matches none Wilcox Gay
6f6, 5z4, no eye, 7 matches 1 Wilcox Gay
Riders 10-1, Model 7E5
http://www.nostalgiaair.org/Resources/588/M0024588.htm" -="window.open(this.href);return false;
6f6, 5y3, yes eye, 7 matches none Wilcox Gay
6f6, 5z4, yes eye, 2 matches both Wilcox Gay
Riders 8-4, models 6F6 and 6FB6
http://www.nostalgiaair.org/Resources/570/M0024570.htm" -="window.open(this.href);return false;
http://www.nostalgiaair.org/Resources/571/M0024571.htm" -="window.open(this.href);return false;
Riders 12-7, models 7C6 and & 7CB6
http://www.nostalgiaair.org/Resources/581/M0024581.htm" -="window.open(this.href);return false;
http://www.nostalgiaair.org/Resources/582/M0024582.htm" -="window.open(this.href);return false;
Some of these hits have bandswitches and or tone controls.
Some also have a chassis layout.
You can use these to help further define if any of these are suitable schematics or model numbers.
palegreenthumb
Apr Sun 01, 2012 8:55 pm
Seattle, WA
Re: Wilcox Gay?
Post by palegreenthumb »
There are a couple other models that were known back in the day as well.
Check this list:
https://grillecloth.com/sylvania/tubeli ... ubmit&db=5" -="window.open(this.href);return false;
Also, here's a link to the post by bobwilson1977:
https://www.antiqueradios.com/forums/vi ... 7#p2909817" -="window.open(this.href);return false;
Rodney -- KG7EPW
Jimradio
Spring Lake, MI USA
Re: Wilcox Gay?
Post by Jimradio »
Thanks guys,
I believe the Rider 8-4 and 12-7 will be very close or the correct ones. Both look the same at first glance.
I errored in the tube line up, it is the 5Z4 stamped on the tube socket. Has an eye tube as well a 6G5.
The picture of Bob Wilson's radio is the same radio.
I am happy with this thanks again, love this forum.
Jim KA8ZXJ
Post Reply
