It is currently Feb Tue 18, 2020 6:57 am
Post New Topic Post Reply  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Make your own SPLICERS
PostPosted: Sep Tue 10, 2019 7:59 pm
I remember using these as a kid. Found a little box with three different sizes of them - I moved it to my workbench.
Dan
PostPosted: Sep Thu 12, 2019 2:47 am
would this work for the lazy man?
https://www.ebay.com/itm/2Pcs-0-2mm-Wir ... zwankmHMaA
PostPosted: Sep Thu 12, 2019 5:29 am
Flinx wrote:
Quick answer: no. You won't be able to solder to spring metal easily.
PostPosted: Sep Mon 23, 2019 8:31 pm
A slight variation of the coiling tool - if you make a tool with 2 parallel pins, one slightly longer than the other, you can insert the lead between them and drive it around to form a good coil. Works well, and does not hurt your fingers :)
With our thoughts, we make the world
PostPosted: Sep Mon 23, 2019 10:47 pm
Another crazy idea and I like it. Your right about the fingers wrapping a lead around a piece of 18 gauge steel wire.
Freeman
PostPosted: Nov Sat 23, 2019 3:47 pm
Why make them when you can buy them ten for $0.29?
Well you could in 1966. :-)
From this 2013 thread,
https://antiqueradios.com/forums/viewtopic.php?t=216079
PostPosted: Dec Fri 06, 2019 2:00 pm
Here is mine, makes work fun.
PostPosted: Jan Tue 28, 2020 2:20 am
Sprague, I think, used to include a couple of those with each replacement capacitor. That is where I first heard the idea.
With the appropriately colored heat shrink, the splice is practically invisible.
Post New Topic Post Reply  [ 28 posts ]  Moderator: Chuck Schwark Go to page Previous  1, 2
