Page 1 of 1
[ 15 posts ] |
Author |
jimbenedict
Post subject: Cheap Audio Transformers Posted: Aug Fri 07, 2020 12:33 am |
Joined: Jan Tue 07, 2020 1:41 am Posts: 3581 Location: Fenton, MI 48430
Did you know you can use a 10 watt 70.7 volt to 8 ohm or (4 ohm with tap on some) for a tube single ended audio transformer. I see these for $5 on ebay. 10 watt rated frequency response is likely 100Hz @ 10 watts, 50Hz @ 5 watts and 30Hz @ 3 watts, All I seen have a gapped lamination core. Here is the resistance chart.
0.625 watt tap= 8000 ohm 1.25 watt tap= 4000 ohm 2.5 watt tap= 2000 ohm 5 watt tap= 1000 ohm 10 watt tap= 500 ohm.
_________________ NAVY JACK FLAG- 'Don't Tread on Me'
Top |
devilsmist
Post subject: Re: Cheap Audio Transformers Posted: Aug Fri 07, 2020 8:00 am |
I would imagine they have a frequency response like a wet noodle.
DM
Top |
NW2K
Post subject: Re: Cheap Audio Transformers Posted: Aug Fri 07, 2020 10:43 am |
Joined: Jan Fri 27, 2017 8:41 pm Posts: 241 Location: Springwater, NY
Have you tested any of the transformers in a single-ended tube amplifier? If so, what makes/models of transformers were tested and what is their max operating DC plate voltage and max operating DC plate current? What is the inductance of the primary and secondary?
Top |
jimbenedict
Post subject: Re: Cheap Audio Transformers Posted: Aug Fri 07, 2020 2:19 pm |
NW2K wrote: Have you tested any of the transformers in a single-ended tube amplifier? If so, what makes/models of transformers were tested and what is their max operating DC plate voltage and max operating DC plate current? What is the inductance of the primary and secondary? I only tested one branded Universal. I do not own a lab. I recommend for a radio, not a high-end audiophile application. I assume the transformer would hold up to 300 volts. The one I owned was wound on a plastic bobbin. I use a choke with a plastic bobbin at 700 volts. Enamel wire itself is rated at 200 volts and if built with fish paper, one layer is likely rated over 100 volts. Transformer should be ok at 300 volts. I know of no radios with a single-ended tube that operates over 300 volts.
Top |
jimbenedict
Post subject: Re: Cheap Audio Transformers Posted: Aug Fri 07, 2020 2:32 pm |
devilsmist wrote: I would imagine they have a frequency response like a wet noodle.
DM Transformers frequency response vs power output is related to lamination core size. The 10 watt 70.7 volt transformer is likely rated at 100Hz. At the power levels used in radios, I believe the low frequency response is sufficient as posted. If the same size core as any other audio transformer, the 70.7 volt transformer would not have less of a frequency response. There is no magic involved. The core is gapped for more inductance like any other single-ended audio transformer. , It is not a interleaved audio transformer, but I doubt 99% of radio audio transformers are interleaved. Interleaved transformers have superior frequency response above 8kHz. Most radios audio transformers are not audiophile quality and are lacking a tweeter. You can always buy a high-end audio transformer yourself. Some cost $500. Your choice. I will stay with the $5 audio transformer myself.
Top |
Retired Radio Man
Post subject: Re: Cheap Audio Transformers Posted: Aug Fri 07, 2020 10:18 pm |
Joined: Jun Sat 09, 2007 8:14 am Posts: 4501 Location: Florida
I've used 70.7 volt transformers as outputs for years and they work fine.
RRM
Top |
jimbenedict
Post subject: Re: Cheap Audio Transformers Posted: Aug Sat 08, 2020 5:22 pm |
Retired Radio Man wrote: I've used 70.7 volt transformers as outputs for years and they work fine.
RRM Thanks. I get a lot of 'it is no good' replies when I post tips.
Top |
joelandjoyce
Post subject: Re: Cheap Audio Transformers Posted: Aug Mon 10, 2020 3:06 am |
Joined: Apr Thu 11, 2013 11:03 pm Posts: 664 Location: 649 Lacy Wilkerson Rd Roxboro, NC 27574
Well, they sound pretty good to me at the grocery store where I have 10 of them installed playing music. Seems like they would work just fine in a radio. I have used a couple that way as well.
_________________ Joel Walker
Top |
Retired Radio Man
Post subject: Re: Cheap Audio Transformers Posted: Aug Mon 10, 2020 3:35 am |
As I said I've used them lots of times with good results. The only concern is that they aren't intended to have dc in the primary and if it's too large the core may saturate. I haven't made any measurements so I don't have any numbers for this but haven't had any problems so far.
RRM
Top |
jimbenedict
Post subject: Re: Cheap Audio Transformers Posted: Aug Mon 10, 2020 2:54 pm |
Retired Radio Man wrote: As I said I've used them lots of times with good results. The only concern is that they aren't intended to have dc in the primary and if it's too large the core may saturate. I haven't made any measurements so I don't have any numbers for this but haven't had any problems so far.
RRM Primary winding DCR measures about the same as a standard audio transformer. I recommend 10 watt rated for no more than 5 watts audio. Most tubes are 3 watts output. All 70.7 volt transformers I seen were gapped to have enough inductance for the DC current.
Top |
mblack
Post subject: Re: Cheap Audio Transformers Posted: Aug Thu 13, 2020 8:01 pm |
Joined: Jun Sun 15, 2014 5:37 pm Posts: 734 Location: Montreal, Quebec
A common suggestion "in the old days"was to use a surplus 400Hz power transformer for modulating a transformer. They were plentiful but cheap since they weren't useful as power gransformers on the 60Hz line.
Top |
szoftveres
Post subject: Re: Cheap Audio Transformers Posted: Jan Mon 11, 2021 6:20 pm |
Joined: Oct Fri 11, 2019 3:03 am Posts: 48 Location: Seattle, WA 98122 (from Hungary)
I once measured the current corresponding to core saturation on the Bogen T725 and the figure was around 15-20mA. So the 10W audio transformer will be able to serve as a Class-A single-ended output transformer to around 1-2 Watts. Purpose built single ended output transformers are air-gapped and have a much larger core size for a given power level. Any comments?
Top |
Post subject: Re: Cheap Audio Transformers Posted: Jan Mon 11, 2021 6:34 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 15350 Location: S. Dartmouth MA 02748-1225 USA
devilsmist wrote: I would imagine they have a frequency response like a wet noodle. DM Yes, designed for Muzak and voice announcement, elevator music
_________________ List' & I will Enchant Thine Ear
Top |
Rich, W3HWJ
Post subject: Re: Cheap Audio Transformers Posted: Jan Tue 12, 2021 6:13 pm |
Joined: May Tue 30, 2006 4:46 pm Posts: 10400 Location: Santa Rosa, CA
Top |
szoftveres
Post subject: Re: Cheap Audio Transformers Posted: Jan Wed 13, 2021 3:02 am |
Rich, W3HWJ wrote: Bogen transformers used in homebrew radios: http://makearadio.com/misc-stuff/t-725.phpAs to "wet noodle".... AM radios aren't exactly "hi-fi." Rich This exact page make me aware of the Bogen T725 a while ago, however the article only mentions the use of this type of transformer as a hypothetical possibility, without ever mentioning the problem of core saturation. I think the author wasn't aware of this problem. I'm sure this transformer will produce sound in an average AA5 as long as the plate current is kept below 10mA, which limits the output power to around 0.5W, even though the transformer could handle way more power in an AC setting. EDIT: the push-pull arrangement is interesting (although not too much radios use a P-P audio), the two currents cancel out each other. The transformer is not symmetrical though, but I guess a decent PP amplifier could be made with a strong negative feedback.
Top |
Page 1 of 1
[ 15 posts ] |
Who is online |
Users browsing this forum: Tony L and 8 guests |
