I've recently converted a
Selena B-211 (
Океан 209) to the 88-108MHz FM and so I thought I'd write up the process, as several of these radios are out there and the process is fairly straightforward as long as everything is figured out (which I did and hence sharing my experience). Also, other Eastern-bloc radios (Sokol-308, etc..) can be converted in a similar way.
The radio had an export version
Selena B-212 with its FM band in the 88-108Mhz range. I am fortunate enough to have this export version available for reference; also, the complete schematic diagrams of both versions are available on the internet. (attached below)
B211-B212.pdf [2.11 MiB]
Downloaded 17 times
The construction of both (eastern and western) versions of the tuner is fairly similar with only minor differences; these differences were insignificant enough for me to take them into consideration (different placement of the D3 clipper diode on the IF transformer, an extra 12 ohm resistor (R12) in the B-211 version, different biasing technique for the AFC varicap, different biasing resistor values of T2, etc..), so I mostly focused on the tuning- and RF component values.
After visually inspecting both tuners (B-211 and B-212), I concluded that all the main tuning components are identical, except L3, which is the coil of the continuously tuned RF LC tank. In the B-211 (66-74MHz) version, this coil has 6 turns, with a tap at the 4rd turn (counted from the bottom). This coil only has 5 turns in the B-212 (88-108MHz) version, with a tap at the 3rd turn from the bottom. So essentially I had to unwind one turn from the bottom of the coil of the B-211 to make it identical to the B-212.
After making L3 coil shorter (and identical to L3 of the B-212), I basically replaced all the RF capacitors to match the values of the B-212 tuner.
C1 30p -> 10p
C2 68p -> 30p
C4 22p -> 10p
C6 75p -> 150p
C9 36p -> 18p
C13 15p -> 4.7p
C17 18p -> 4.7p
C19 13p -> 6p
I used oscilloscope (at the oscillator coil tap, through a 1p capacitor to the probe) to set the tuning range of the oscillator between approximately 98-119MHz (10.7MHz above). After all this was done, I re-installed the tuner and did a final alignment on it.
The alignment is pretty straightforward: find a mid-weak station at midband (around 98MHz) and peak up the reception with adjusting L1 and L3, using the tuning indicator of the radio. None of the IF tanks need alignment as long as the IF tuning is in factory condition.
Usually this is the point where similar FM conversion works are considered finished, with disappointing results. The radio is harsh-sounding and FM audio is distorted. The poor quality -especially the distortion- is usually attributed to the
assumed inaccurate alignment of the radio and the tuner.
However the poor sound quality has surprisingly nothing to do with the tuner, or with the alignment, if otherwise the IF section was untouched. The harsh sound is the result of different pre-emphasis used in Europe and in the U.S. (75us vs. 50us); the distortion is caused by the deeper modulation used on the 88-108MHz band, which overdrives the IF stages and the FM ratio detector of the Eastern-bloc radios.
Bridging the de-emphasis capacitor (C142, 6.8n) across with 3.3n (or replacing it with 10n cap) fixes the de-emphasis and the radio doesn't sound harsh any more.
The overdrive comes from the difference in modulation level of the two bands. The Eastern-bloc 66-74MHz band used approximately +/-50KHz modulation depth and hence the narrower-band IF stages and the sharper FM detector of these radios distort with the +/-75KHz modulation depth, which is the standard on the 88-108MHz band. Since re-designing and re-building the entire FM IF strip is impractical (yes, the B-211 and B-212 radios have different IF strip and detectors, due to the different modulation depths), a relatively easy and effective solution is
modulation compression, i.e. a small portion of the audio signal is fed back to the AFC varicap diode, which then works against the FM modulation and hence reduces the frequency deviation that is reaching the IF stages and the FM detector.
I added an audio signal path in parallel with the existing AFC path. It's important that the audio is taken directly from the detector, i.e. before the de-emphasis network and any filtering. The two added 47k resistors form a voltage divider between the ratio detector and the ground (whether the AFC is switched on or off, via C143 and the added 100n cap). The added 47p capacitor keeps RF out of the loop. The 47k resistor on the detector side is soldered directly to one of the leads of the electrolyte buffer cap (C141) of the ratio detector, in order to get 100% pure detector output.
Sketch attached. The top drawing is the original AFC network of the radio, the bottom drawing depicts the extra audio feedback for the modulation compression, with the added extra components circled and marked.
The added resistor values should be as high as possible in order to minimize the load on the ratio detector, but also low enough so that the low-pass filter formed by the added resistor (in this case 47k), R10 (56k) and the varicap itself (somewhere in the 10p range in this case) still allows the full audio bandwidth to modulate the varicap.
The overall result is decent FM reception and enjoyable audio quality on the 88-108 band.
