It is currently Jan Fri 21, 2022 11:50 am
Post New Topic Post Reply  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Cleaning bakelite knobs
PostPosted: Sep Thu 20, 2012 12:24 am
I'm on the U S cleaner wagon. I have cleaned tuning caps, trimmers, tube sockets, knobs, etc in that thing. Basically anything I can get into the tank. Its also good for glasses, watches, jewelry and other stuff. Also empty brass for reloading, model engine parts and gun parts. You don't have to use water either, it can be a solvent but you have to be careful whether the solvent will attack the plastic parts of the cleaner. I found that you can put water in the tank, put the parts and solvent in a smaller container and let it float around in the water while you run the cycle. Works great.
One other thing, it will take the paint off a dial scale so be careful with that. Don't ask how I know that tidbit.
-Don.
PostPosted: Oct Thu 28, 2021 11:09 pm
jbivy wrote:
Ive found rather good results using cheap toothpaste, it usually has more grit. Using a dremmel tool with only a buffing wheel, it seems to get them rather good. Then a light jewelers rouge for final polishing. I tend to rub then down with boiled linseed oil afterwards, it seeps in and when wiped off, theyre shiny and new looking.
Toothpaste worked like a charm on some knobs from a Philco 40-180. Nice trick. Thank you.
 Post subject: Re: Cleaning bakelit knobs
PostPosted: Dec Mon 13, 2021 4:43 am
cwmoser wrote:
I use a Harbor Freight $20 Ultrasonic Cleaner that works very good.
Drop my knobs in the tank along with some cleaner and let it do its job.
Me too, except my ultrasonic is not a Harbor Freight, but similar. It works very nicely on knobs. Gets all the little details clean. I use a bit of LA Awesome cleaning solution in distilled water.
PostPosted: Jan Sat 15, 2022 2:00 am
I use an electric toothbrush and ammonia. Works really well for me. Just donā€™t get it mixed up with your other dental electric brush. :wink:
