Page 1 of 1
[ 13 posts ] |
Author |
Jim Dutridge
Post subject: Ideas for a jig Posted: May Tue 10, 2022 9:29 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8145 Location: Toledo, Ohio
Looking for ideas to make a jig for cutting a straight line around those round wet electrolytic cans. All I have is a Dremel tool and a shaky hand.
_________________ Jim KE8GMW --------------------- I have flying monkeys and I know how to use them.
Top |
Freeman
Post subject: Re: Ideas for a jig Posted: May Tue 10, 2022 10:31 pm |
Member |
Joined: Dec Tue 23, 2014 6:51 pm Posts: 2719 Location: N. Palm Bch, Fl.
I haven't come across anything but the Dremel or hacksaw. Hacksaw turned sideways has made it easier sometimes. Last week I had one with IF cans on 2 sides. 1/4" clearance between them. The one handed hacksaw worked there, but it took quit a while to finish it. It will be interesting if someone else has a better trick.
Freeman
_________________ What's built by man can be fixed by man.
Top |
lasermike
Post subject: Re: Ideas for a jig Posted: May Tue 10, 2022 10:32 pm |
Joined: Dec Tue 07, 2021 4:28 am Posts: 83 Location: Des Moines, WA
I would think some sort of V block would help a lot. Especially if it has an end stop to control how much of the can is sticking out. That would eliminate at least one variable, making it much easier to get a controlled cut. You can buy V blocks, you can make one on the table saw or you could get a few feet of corner molding and glue it to a board. Doesn't need to be fancy but should be smooth enough that the can will turn nicely. Once the can is in the V block, you can try stacking something up for your hand to rest on or against. I find that the more points of contact I have when doing fine work like cutting something with a Dremel, the better the end result. Even just setting something heavy to rest the back of the hand against helps.
Michael
Top |
N2LXM
Post subject: Re: Ideas for a jig Posted: May Tue 10, 2022 10:33 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1942 Location: Wayside, NJ Monmouth
Large tubbing cutter. I made a holder, by drilling a hole the size of the can into a piece of 5/4 stock. Push the can in, then use a fine tooth hack saw. To cut around the can.
Top |
Jim Dutridge
Post subject: Re: Ideas for a jig Posted: May Tue 10, 2022 11:13 pm |
A large tubing cutter never crossed my mind. The V idea did cross my mind but with my shaky hand it still would result in a crooked cut.
Top |
Dale Saukerson
Post subject: Re: Ideas for a jig Posted: May Wed 11, 2022 12:10 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6616 Location: Minneapolis, MN USA
Using narrow strip of paper perhaps 1/2 inch wide you can wrap at the cut line a couple dozen times creating a bushing you can guide a razor saw or x-acto knife against. Can using something besides paper as long as it wraps easy and doesn't fracture doing so. This method gives you a custom size bushing without having to source something to exactly fit the diameter of each electrolytic can.
Attachments: |
Last edited by Dale Saukerson on May Wed 11, 2022 12:27 am, edited 1 time in total.
Top |
Jim Dutridge
Post subject: Re: Ideas for a jig Posted: May Wed 11, 2022 12:20 am |
Another good idea. Thanks Dale.
Top |
lwhite46
Post subject: Re: Ideas for a jig Posted: May Wed 11, 2022 12:52 am |
Member |
Joined: Aug Tue 21, 2012 1:19 am Posts: 206 Location: Southern Ontario
I use a Oscillating Multi-Tool. It has many attachments for tight spaces. Hold it steady on a V block and work slowly to reduce vibration. It makes a very clean cut. Check Amazon, Harbor Freight or Canadian Tire. Here is an Amazon link. https://www.amazon.com/AIOPR-Oscillatin ... 23&sr=8-20Are commercial links allowed here?
_________________ Lee
If you can't figure it out, cool the iron and start your day over.
Top |
cl350rr
Post subject: Re: Ideas for a jig Posted: May Wed 11, 2022 12:55 am |
Member |
Joined: Oct Sat 15, 2011 12:19 am Posts: 2737 Location: 23452
if you have access to a drill press, you can put a small saw arbor like for a Dremel in the chuck, set the table for the height you want to cut and turn the cap around with the blade cutting. fairly easy to control
Top |
jimtech
Post subject: Re: Ideas for a jig Posted: May Wed 11, 2022 2:14 am |
Member |
Joined: Nov Sun 29, 2020 5:59 pm Posts: 521 Location: Carol Stream, Illinois 60188
cl350rr wrote: if you have access to a drill press, you can put a small saw arbor like for a Dremel in the chuck, set the table for the height you want to cut and turn the cap around with the blade cutting. fairly easy to control This technique also works well with a real Dremel tool using the Dremel drill press stand or the Dremel Drill Press Workstation.
Top |
Scott
Post subject: Re: Ideas for a jig Posted: May Wed 11, 2022 2:23 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7294 Location: Montvale NJ, 07645
The problem with tubing cutters is that they make a nice "V" in the aluminum before cutting through. Jewelers saw seems to be the best, though I have never tried that, but I have seen the clean results. Look at the beautiful work Mondial did in this thread: viewtopic.php?f=19&t=412796
Top |
Dennis Banker
Post subject: Re: Ideas for a jig Posted: May Sun 15, 2022 10:53 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1311 Location: St. Louis, MO, USA
I got a hand held tubing cutter that can cut around a capacitor up to 2” in diameter. I can cut it in two in less than 5 minutes. I then grip the can and twist. The insides come right off.
Top |
GalaxyBeing
Post subject: Re: Ideas for a jig Posted: May Tue 17, 2022 3:39 am |
Member |
This weekend I did an excellent job re-stuffing 2 electrolytic cans on my Ampex 850. I cut the leads leaving enough to identify them for later splicing. Then I twisted the 4 tabs back straignt so as to pull out the can. Then I proceeded with my die-grinder on the bottom END of the can. After carefully grinding through the crimped end of the can the tabbed ring underneath the crimped end of the can just came right out. Then I heated up the can at 350F in the oven so the guts could be pulled out. I recapped the phenolic disc by drilling small holes behind the contacts for the positive lead of the radial caps to slip through. The neative leads all went trough a small hole I drilled in the center of the phenolic disc, which I soldered a wire to. Then I slipped the disc with the new caps back into the can, put the tabbed ring back in using some hot glue. Then I used a screwdriver to make little crimps around the diameter of the end of the can for good measure. When I re-installed the can cap, you couldn't even tell it had ever been out, except for the little crimp nicks. As for the negative leads with the wire in the middle of the disc, I soldered the wire to one of the twist tabs. Took about an hour and a half per can. Well worth it. I have previously hack-sawed through the outside of cans down near the bottom. But I just wasn't willing to settle for such an obvious repair.
Top |
Page 1 of 1
[ 13 posts ] |
Who is online |
Users browsing this forum: No registered users and 2 guests |
