It is currently May Mon 25, 2020 12:58 pm
 Post subject: Loose Ferrite Antenna Bar
PostPosted: Jul Sun 08, 2018 8:10 pm
When working on my 1965 Magnavox Astrosonic the ferrite bar for the AM antenna came loose because the cardboard tabs that held it broke off so I cut a piece of cloth and soaked it with wood glue and stuck it back where it belongs and let it dry and it hasn't moved since.
cook#yum
 Post subject: Re: Loose Ferrite Antenna Bar
PostPosted: Aug Wed 22, 2018 4:54 pm
Good fix.
I dropped a Sangean AS909 that I once had, which broke the ferrite bar into three pieces.
Super glued it and could detect no change in performance. The mess looked worse than it was.
SUPPORT YOUR RIGHT TO REPAIR!
Post New Topic Post Reply  [ 2 posts ]  Moderator: Chuck Schwark
