It is currently Aug Sat 17, 2019 7:07 pm
 Post subject: Honey, can I borrow your micro-electronics heat sink ?
PostPosted: Mar Sun 27, 2016 8:31 pm
I am sure this is not an original idea and that this has been covered amply over the years.
However I thought I would share it because it got me out of a bind while I was
soldering wire-wraps onto an LCD display.
I tried using the smallest sized alligator clips I had and even grinded some of then
down to narrow the "jaw" lines. As soon as solder touched it, it became soldered to
the pins as well. I could see myself ruining this repair.
Having no brass or aluminum alligator clips I started scrounging around and remembered
my wife's make-up desk. Sure 'nuff...she had some long aluminum clips that I could
grind down that would work nicely as a soldering heat sink.
One suggestion: If you use the "Goody" brand of hair clips you will have to modify it
a bit. First, they made them very cheaply and the tension spring isn't even secured inside the clip; it just sits in a little trough. I also drilled out the crimped pivot points and inserted a pop rivet wire through one jaw, into the center of the spring and then exiting out the other jaw's side. I could not rivet it; I just used a 1/8-inch pop rivet wire because it was the right size. A nail would work just as well. I terminated each side of the axle by using the pop rivet "head" on one side and, on the other, I placed it in a vice and use a chisel to flatten the axle as it came out of the jaw. When I smacked the chisel it not only flattened the side I wanted to hold it in place but, at the same time, it cut off the excess length of the pop rivet wire; so I got a "two-fer."
Now, where did I put my bobby pins? My hair's a mess.
 Post subject: Re: Honey, can I borrow your micro-electronics heat sink ?
PostPosted: Mar Sun 27, 2016 9:05 pm
Just the thing for" a bad hair day"... :wink:
Great tip, and I personally haven't seen this idea previously posted on the forum.
PostPosted: Mar Sun 27, 2016 9:27 pm
A very good idea!
I'm a regular at our local beauty supply place - it never ceases to amaze me how many things they sell that turn out to be useful in the hobby.
PostPosted: Mar Mon 28, 2016 5:21 am
For future reference, brass solders quite readily. Steel is harder to solder. I've never heard of aluminum alligator clips, but I wouldn't be surprised if there were some Chinese ones.
Jim Mueller
Jim Mueller
Post New Topic Post Reply  [ 4 posts ]  Moderator: Chuck Schwark
