It is currently Dec Sat 07, 2019 8:17 am
 Post subject: How to retrieve worn off tube numbers
PostPosted: Apr Sat 02, 2016 12:07 am
I learned of this trick from a PDF of a 1950 radio magazine that I was looking at for a schematic. If you can't read the number of a tube, rub a pencil "lead" (graphite today) over it, look at it under a light such as a flashlight or desk lamp, and you can see the numbers. Apparently this works because of the way tube numbers were embossed on the glass, leaving an indentation. I used this to retrieve the tube numbers from my Lear 562-more on that in the electrical restoration forum.
 Post subject: Re: How to retrieve worn off tube numbers
PostPosted: Apr Sat 02, 2016 10:21 pm
This is a great tip.
I've tried all sorts of techniques from freezing them, bringing them
out of the freezer and trying to read numbers; black light; breath vapor;
all with so-so results.
I couldn't wait to try this one and, by gosh, it worked! I had to find a
pencil with a very soft "lead." The new pencils all seem to be made of
Chinese crappy who-knows-what and even on white paper make
an anemic gray shadowy line. Pencil grading numbers yielded inconsistent
results so I couldn't really go by what number or HB value was noted.
But I found an old pencil (Jay's Potato chips...remember when they gave those
away?) that makes a really well-defined dark line and it brought the tube numbers through nicely.
Thank you BakelitemanCA for sharing.
PostPosted: Apr Sat 02, 2016 11:33 pm
Try art pencils rather than office supply pencils. They come in a variety of grades. As long as you stick to the same brand, you can tell if a given pencil is harder than softer than another. But the numbers aren't consistent across brands. You get them at an art supply store.
Jim Mueller
Jim Mueller
PostPosted: Apr Sun 03, 2016 12:20 am
A 5 or 7 mini LED flashlight seems to work rather well too.
Chas
PostPosted: Apr Mon 04, 2016 4:04 am
Sunlight and a 10 power loupe are a great help especially if you are on the top side of 70!
PostPosted: Apr Tue 12, 2016 7:02 am
I find a little "face oil" off my forehead brushed onto the glass does the trick 90% of the time. View it under your bench magnifier lamp at various angles. TIP: the markings are nearly always above the KEY of the base, so look there. The KEY of fat pin tubes (6A7, 78, 26, 42, 2B7 etc) is considered between the two fat pins.
After WW2, the marking can be anywhere.
Mark Oppat
Post New Topic Post Reply  [ 6 posts ]  Moderator: Chuck Schwark
