It is currently Oct Wed 20, 2021 11:52 pm
Post New Topic Post Reply  [ 35 posts ]  Go to page Previous  1, 2
 Post subject: Re: Fix Hole In Speaker
PostPosted: Jan Fri 25, 2019 7:29 pm
I had a large speaker that was a victim of archery practice. I got some black construction paper, wetted it with some flowable silicone, applied some around the hole and patched it, taking away the excess. It made a nice repair.
— Arthur C. Clarke
PostPosted: Jan Sat 26, 2019 8:27 am
I remember now. Years ago I repaired a speaker whereas it was the "surround" that I fixed and I used a flexible, never drying-out silicon sealer. That seemed logical to me at the time.
I just found lots of info with a Google search on "Speaker Cone Repair" and "Speaker Parts".
cook#yum
PostPosted: Feb Sun 10, 2019 7:17 pm
Contact cement works very well. It drys quickly and is very flexible. For tears, I spread a thin layer along the tear. for holes, I use one ply of paper towel and the contact cement. Use the minimum necessary to cover the hole and make sure the paper is saturated in the glue. feather the glue out from the hole with a small brush. I've had excellent results using this method.
PostPosted: Feb Sun 10, 2019 7:39 pm
I recall in college, where rolling papers seemed to abound (ya know Zig-Zag and the like—ah, those were the days), repairing the tweeter from a beloved set of Harmon Kardon HK40's with several layers of "papers" and rubber cement. I kinda had to use what I had on hand. Worked great. I wish I still had those old HK's...
PostPosted: Apr Wed 24, 2019 1:59 am
How does that fix a hole in the paper speaker cone?
PostPosted: Apr Wed 24, 2019 3:00 am
Guess it does good if you have solder in it.
— Arthur C. Clarke
PostPosted: Apr Wed 24, 2019 1:04 pm
Three of his four posts are either misplaced or confused.
PostPosted: Apr Thu 25, 2019 11:29 am
Paper Solder would be an interesting trade name for some kind of super paper glue product ........
Or who knows. Maybe someone soldered the paper. ;-)
PostPosted: May Wed 08, 2019 6:18 am
I use manilla business envelope paper. You can paint it flat black or some such if you want first. Its the right stiffness and is cheap and easy to get. I have made whole cones out of it. Do a search here on the ARF for "Mark Pictures" and you will see one I did a few years ago.
Mark Oppat
PostPosted: May Wed 08, 2019 1:46 pm
Mark Oppat
https://antiqueradios.com/forums/viewto ... epair+mark
PostPosted: Aug Mon 31, 2020 2:05 am
Back in the 60's in the radio class in high school, we used model glue and toilet paper for most tears.
PostPosted: Aug Mon 31, 2020 7:25 pm
One ply or two ply? lol
cookie#yum
PostPosted: Oct Sun 04, 2020 3:04 am
Here’s another thread on speaker repair....
https://antiqueradios.com/forums/viewtopic.php?f=6&t=350672
.....Dennis.....
Live Long and Prosper
PostPosted: Dec Fri 18, 2020 1:41 am
I recently repaired a 5" speaker with 5 tears in the paper, one tear was from cone to edge. I use teabags, as they are impossible to tear, are porus, which allows the adhesive to completely saturate the patch. I also make a very thin milk paste from latex caulk ( a bit of water and a brush to mix to a milk consistency). I cut patches from the teabags to overlap the tear then soak the patches in the milk, meanwhile, I use a small flat art brush and apply a coat of milk to the speaker paper along the tear, shake of the excess from the patch and carefully place it on the speaker, then starting from the center of the patch outward toward the edges using the brush to smooth out any wrinkles or air bubbles. I also applied patches on the underside of the speaker over the tears also. Let dry overnight and then apply a second coat of the latex milk over all patches and again let dry. The latex milk paste remains flexible when dry and allows the speaker to flex more than super glue or Elmers glue which both dry very hard and rigid. The flexibilty is important when the volume is turned up! Anyway, this has worked well for me on a couple of speaker repairs I've done. :)
PostPosted: Oct Fri 08, 2021 5:25 am
Best to add as little mass as possible.
As previously mentioned, if there is no loss of cone material try to get the ripped edges back together. Then use single ply toilet paper and Elmers glue diluted with RO or distilled water, using only a big enough piece of toilet paper to cover the rip.
The RO or distilled water means nothing is left behind after evaporation. Diluting the glue reduces the amount of glue required and helps it get deep into the tiny fibers of the cone.
I used this technique on Altec Lansing LF VOTT speakers whose cone material is regarded among the best ever made.
Jeff
