It is currently Mar Thu 21, 2019 6:40 am
 Post subject: PUT the TUBE shields on
PostPosted: Sep Sun 02, 2018 4:34 pm
I recapped a Westinghouse mode 165 and I could not get anything but a loud motor boating high pitched sound out of it.
A good friend who was helping me find the problem said ''Make sure the tube shields are in place''.
I did not have tube shields when I bought it so I never thought much about it, but after putting them on it works very well
It was a tough lesson learned , but one I won't forget.
MAKE SURE THE TUBE SHIELDS ARE IN PLACE
Dan in Calgary
 Post subject: Re: PUT the TUBE shields on
PostPosted: Sep Sun 02, 2018 4:39 pm
:D
PostPosted: Sep Sun 02, 2018 6:55 pm
Hi Dan,
Yes, this is good advice. Sometimes the presence or absence of a tube shield seems to make little difference. Other times (as in your case) it makes all the difference in the world.
Since all manufacturers were concerned about cost, we have to assume that tube shields were seldom used unless they felt there was a good and sufficient reason to do so.
Poston
PostPosted: Sep Sun 16, 2018 4:56 am
here is a thread I started on the infamous motorboating, squealing, variable frequency howl when tuning a station.
http://www.antiqueradios.com/forums/vie ... 6&t=302323
steve
PostPosted: Sep Tue 25, 2018 2:31 am
I have a sneaking suspicion that my theremin might need these.
Mark
PostPosted: Oct Mon 01, 2018 5:22 pm
Watch out for those late 20s and early 30s sets which had one-piece shields with dividers between the tubes; sometimes, they are missing.
PostPosted: Oct Sun 07, 2018 4:30 am
yes ! Especially the Philco 20. 70, 90 series. You can peak them worth a darn without them oscillating unless the shields are on. Seems they are often missing. Thats why I had repro's made of those 3. Had them at Kutztown on my tables, some of you commented about them.
Mark Oppat
Post New Topic Post Reply  [ 7 posts ]  Moderator: Chuck Schwark
