It is currently Oct Sun 24, 2021 7:09 pm
Post New Topic Post Reply  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: BNC Wrench
PostPosted: Sep Thu 13, 2018 12:22 am
Needed to mount up some chaise BNC connectors. Always had a problem holding them while tightening the mounting nuts. So I made this up. Took an old Craftsman 3/8" nut driver( head was cracked) ground it down so it would fit into the end of a BNC ( most of us have cable connectors laying about cable connector missing there pins) connector. I used a small gas torch and Silver solder to weld it up. Now mounting the connectors is a breeze.
 Post subject: Re: BNC Wrench
PostPosted: Sep Thu 13, 2018 1:36 am
Clever! Next time someone asks to borrow a nut driver hand them that and watch the reaction.
Jeff-W3JKO
https://ornerscorner.neocities.org
PostPosted: Sep Thu 13, 2018 2:53 am
Nice job !!
PostPosted: Sep Fri 14, 2018 8:45 pm
That is clever. Now I just need to find something I can use as a handle as my nutdriver sets cannot be sacrificed. I do have a bunch of my Dad's old screwdrivers and I'm sure that one will suffice.
PostPosted: Sep Sun 16, 2018 7:23 pm
That's the way to do it.
I made this one back in the early 80's
Was helping a buddy with cable tv installations one summer so I just copied his tool.
it's just an F coupler glued to a 7/16 driver. Only the threaded end sticks out.
Great for pushing the connectors into the cable.
Rocco
PostPosted: Sep Sun 16, 2018 7:31 pm
Hello Rocco53,
I guess great minds think alike I did the same thing years ago when was doing a coax work with my repairshop
what great idea far the bnc connector
PostPosted: Sep Sun 16, 2018 8:43 pm
radiorich wrote:
Hello Rocco53,
Our job was actually out in the field locating underground breaks in cables. (subcontract for cable co.)
We had a machine similar to the one in the photo that shows how far down the line the cable is broken.
It was amazingly accurate, sure saved a lot of time digging in the wrong place.
Rocco
PostPosted: Sep Mon 17, 2018 1:42 pm
Rocco53 wrote:
That is a metallic time domain reflectometer. I use a fairly early one, a Tektronix 1503 (as Scotty said in ST:TNG "Relics" - "No bloody A, B, C or D").
PostPosted: Sep Mon 17, 2018 2:45 pm
Dale H. Cook wrote:
Thank you Dale, I couldn't remember exactly what it was called.
Rocco
PostPosted: Sep Tue 18, 2018 12:53 am
Rocco, its counterpart is the optical time domain reflectometer used for testing optical fiber.
PostPosted: Sep Tue 18, 2018 3:06 am
interesting, Tektronix has a line of these as well.
I know the principals of fiber optic but I worked in the field long before it became widely used.
I imagine these pieces of equipment are quite expensive.
Rocco
PostPosted: Dec Thu 13, 2018 12:09 am
If you look around on the internet you can find out that you can use a function generator and an Oscope for RF cable.
Visit our site:
I was smokinradios Long time ago (2004)
PostPosted: Jan Wed 02, 2019 6:14 pm
I use my Tek probe calibrator output to drive the cable and watch the reflection on the scope; mostly use it on cables in the shop, not long outside cable.
Ex: Same job, same building, same phone #; 4 Corp's: RCA, GE, Martin, Lockheed-Martin: 48+yrs '14
PostPosted: Jan Wed 02, 2019 6:41 pm
The results of that are, for my professional purposes, not as satisfactory as a Tek TDR which can be set for velocity factor and accurately show where the problem is. Tower crews are expensive, and radio station loss of revenue is expensive, and it is my responsibility to minimize both. When trying to locate a problem in hundreds of feet of coaxial cable, some of which costs tens of dollars per foot, running up a tower, one needs quality instrumentation. Replacing a cable run that can cost thousands of dollars is something to be avoided if possible. The function generator/'scope method is fine for hobby use, but the ARF membership also includes many who must use lab grade instrumentation to make a living. YMMV.
Dale H. Cook, Radio Contract Engineer, Roanoke/Lynchburg, VA
https://plymouthcolony.net/starcityeng/index.html
PostPosted: Jan Wed 02, 2019 7:17 pm
I understand your conundrum, But since I am retired I have no problems using my method (Fixed Retirement income).
There are a couple of other methods, one is using a resistance bridge, it was used before cable companies and optical fiber.
Telephone companies used it for very long runs, ( I believe there were a couple methods, called Varley Loop and Murray Loop
Of course Our Shop depended on Tektronix's TDRs heavily.
However when Power was lacking we used Leeds and Northrup test Instruments in the field. Image
Visit our site:
PostPosted: Jan Wed 02, 2019 7:35 pm
Fortunately that is not a problem that I normally face, as nobody is doing much of anything at a radio transmitter site if there is no power, with the possible exception of me working on getting power restored. :-)
PostPosted: Jan Wed 02, 2019 8:06 pm
A couple of cheaper methods for us that don't have Business write-offs:
MFJ-269C Testing coax cable faults and length
will also show Db loss.
https://www.youtube.com/watch?v=QnRYYfgVToE
And using a digital meter with a capacitance function
https://www.circuitspecialists.com/blog/using-a-digital-multimeter-to-locate-a-buried-cable-fault/
Visit our site:
PostPosted: Jan Wed 02, 2019 8:11 pm
I do that at times as I keep a list of capacitance measurements for some transmission systems in my care. It is an excellent and simple check if one knows what the meter should read. If it does not read correctly it is time to break out the TDR.
PostPosted: Jan Wed 02, 2019 10:29 pm
OK I have a question. How did my posting about making a wrench to hold and tighten BNC connectors turn into a discussion about checking coax cables. Not an issue really, just wondering.
PostPosted: Jan Wed 02, 2019 10:58 pm
Right about 14 posts back, there was a very smooth transition. Sorry, i also contributed to the hijack. I do not believe there is an editing function to split off the interlopeing new topic as its own new thread.
But you are able to edit the topic title to add on something like "and cable fault locator TDR measurement" if you wanted too.
Beautiful job you did making your BNC wrench, by the way.
