It is currently Mar Mon 25, 2019 4:35 am
 Post subject: TROUBLE SHOOTING BAD JOINTS CIRCUIT BOARDS
PostPosted: Jan Fri 18, 2019 8:11 pm
One thing I found in the 2way radio repair, use 1 thick paint brissel AKA (cats WhisKker) and tickle the area that would equate to the radio's problem esp intermittent problems . Had a commercial Kenwood ht ,intermittent rx audio, after the whisker tick I found the cold solder joint. radio worked fine after that. Use thicker brissels for more stubborn areas. Good luck. EF JOHlNSON TECH.
JR
 Post subject: Re: TROUBLE SHOOTING BAD JOINTS CIRCUIT BOARDS
PostPosted: Jan Sat 19, 2019 2:14 am
A ESR tester also works good for finding breaks in PC boards.
PostPosted: Jan Fri 25, 2019 7:35 am
Freeze spray ! Great for smoking out intermittents.
Mark Oppat
PostPosted: Jan Fri 25, 2019 4:03 pm
Mark Oppat
Yeppers! Makes a frostline at the crack!
Not tools that any "normal" tech would have:
Vortac circuit cooler, uses compressed air to make cold air stream...
Ultra small heat gun, has silicone rubber nozzle to direct heat onto suspect parts..
PostPosted: Jan Sun 27, 2019 4:48 pm
When looking for intermittent mechanical causes of electronic problems I sometimes use a custom-built spot vibrator. I also use thermal cycling as mentioned upstream.
PostPosted: Mar Wed 06, 2019 7:22 am
I am given to understand that a UV light aka Black Light, helps too. Shine it on the board and supposedly cracks and bad solder joints will show up.
FrankB
WB7ELC
"The average family has 2.5 children. Where is the other .5 child?"
PostPosted: Mar Tue 19, 2019 7:28 pm
I sometimes just rework the solder joints in the area of interest where the problem seems to be. One thing is where they snip the leads too close and cut off part of the solder blob with a flush cutter. Those can result in bad solder junctions. Reflow with new solder.
Post New Topic Post Reply  [ 7 posts ]  Moderator: Chuck Schwark
Users browsing this forum: k9uw and 3 guests
