It is currently Oct Wed 23, 2019 11:47 am
 Post subject: Marking tested tubes
PostPosted: May Wed 01, 2019 9:12 pm
Whenever I test tubes in a radio or TV, and they test good, I apply a dot of green acrylic paint, like you get in craft stores, on the top shoulder of the tube with a Q-tip. Never any "Did I test that tube?" questions.
Stan Saeger
Coopersburg, PA
http://www.saegerradio.com/
 Post subject: Re: Marking tested tubes
PostPosted: May Wed 01, 2019 9:47 pm
I like that idea. MISS works every time.
Freeman
Edit: I wish I had paid attention in the English class.
PostPosted: May Thu 02, 2019 9:32 am
Does it burn when the tubes get hot? Long, long ago I tried fingernail polish and found that on hot tubes it would burn and turn brown as well as smelling bad.
Jim Mueller
PostPosted: May Thu 02, 2019 12:00 pm
I've never had a problem with the paint burning.
Stan Saeger
Coopersburg, PA
PostPosted: May Tue 14, 2019 7:38 pm
For tubes with black plastic bases I just write on them with silver permanent marker. For all-glass tubes I use black permanent marker... doesn't look great, but the electron have not complained yet!
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: May Fri 17, 2019 3:34 am
I label all tubes with a tiny label that shows results of the mutual conductance test. It's time consuming, but I know exactly what I have.
Bakelite bases get the tube number engraved... just in case the number gets wiped off the glass in the future.
PostPosted: May Fri 17, 2019 3:42 am
I engraved the bakelite bases of a couple of tubes with my laser cutter, but it was too much trouble, so now I just label them with brother labeler.
I like this better.
Paul of Florida (Click below for my collection)
PostPosted: May Fri 17, 2019 4:59 am
I do the silver marker on the glass, the tester reading over the chart value. The marker is easily removable with solvent.
Wish someone would offer water-based stickers like are found on vintage tubes.
Chas
PostPosted: May Sun 19, 2019 8:16 pm
I use red, green, and yellow self adhesive paper dots. The dot color corresponds to the meter markings for bad, good, and marginal. I put the dot on the top of the tube for visibility when it's in a box or inside a radio. They are easily removed if desired.
- Mike
When your memory goes, FORGET IT!
PostPosted: May Mon 20, 2019 4:11 pm
I would not mark the glass on a hi temp tube (rectifier or power output) with ANY material.
https://www.bulbs.com/blogs/light_sourc ... Care!.aspx
A common cause of early failure for quartz halogen bulbs is surface contamination, and the most likely source of contamination comes from touching the glass portion of the bulb with bare skin. Even clean skin will leave behind oils. This contamination causes a hot spot when the bulb is operated, which can result in cracks or bubbles that will allow halogen gas to leak out, resulting in early failure
PostPosted: May Tue 21, 2019 7:38 pm
I found that the curved surface of bakelite tube bases tends to shed adhesive paper stickers over time. I would prefer the more permanent paint mark.
PostPosted: May Thu 23, 2019 4:44 pm
Here is an illustration of how I label the test results for mutual conductance... a tiny label and scotch tape. You can faintly see the engraved tube number on the bakelite base on the right.
No angst for future collectors if the tube number is removed from the glass. I have a number of tubes with no ID.
Post New Topic Post Reply  [ 12 posts ]  Moderator: Chuck Schwark
