It is currently Jan Tue 25, 2022 12:27 am
 Post subject: Cal Source and Movement Checker
PostPosted: Dec Fri 18, 2020 8:41 pm
I use this little klooge for calibration and to check meter movements. It's built up on a piece of wood with a small piece of masonite for a front panel. There are two binding posts and two pin packs. The pin jacks are convenient for a DMM when using it as a calibration voltage source. To check a movement, connect a DMM in series with the movement. Start with the pot fully counterclockwise.
A ten-turn pot makes it easier to set precisely. The 4.7 K limits the current. The LED isn't necessary but helps not leaving it on and draining the battery.
Having something like this around is a lot handier that having to set up something each time you need it.
RRM
Cal Source.pdf [157.43 KiB]
Downloaded 168 times
 Post subject: Re: Cal Source and Movement Checker
PostPosted: Dec Fri 18, 2020 9:36 pm
The next step would be to add a Bandgap Reference for really accurate voltages.
https://www.analog.com/media/en/technic ... 6657fd.pdf
