It is currently May Sat 08, 2021 11:16 pm
 Post subject: Cheap Audio Transformers
PostPosted: Aug Fri 07, 2020 12:33 am
Did you know you can use a 10 watt 70.7 volt to 8 ohm or (4 ohm with tap on some) for a tube single ended audio transformer. I see these for $5 on ebay. 10 watt rated frequency response is likely 100Hz @ 10 watts, 50Hz @ 5 watts and 30Hz @ 3 watts, All I seen have a gapped lamination core. Here is the resistance chart.
0.625 watt tap= 8000 ohm
1.25 watt tap= 4000 ohm
2.5 watt tap= 2000 ohm
5 watt tap= 1000 ohm
10 watt tap= 500 ohm.
 Post subject: Re: Cheap Audio Transformers
PostPosted: Aug Fri 07, 2020 8:00 am
I would imagine they have a frequency response like a wet noodle.
DM
PostPosted: Aug Fri 07, 2020 10:43 am
Have you tested any of the transformers in a single-ended tube amplifier? If so, what makes/models of transformers were tested and what is their max operating DC plate voltage and max operating DC plate current? What is the inductance of the primary and secondary?
PostPosted: Aug Fri 07, 2020 2:19 pm
I only tested one branded Universal. I do not own a lab. I recommend for a radio, not a high-end audiophile application. I assume the transformer would hold up to 300 volts. The one I owned was wound on a plastic bobbin. I use a choke with a plastic bobbin at 700 volts. Enamel wire itself is rated at 200 volts and if built with fish paper, one layer is likely rated over 100 volts. Transformer should be ok at 300 volts. I know of no radios with a single-ended tube that operates over 300 volts.
PostPosted: Aug Fri 07, 2020 2:32 pm
DM
Transformers frequency response vs power output is related to lamination core size. The 10 watt 70.7 volt transformer is likely rated at 100Hz. At the power levels used in radios, I believe the low frequency response is sufficient as posted. If the same size core as any other audio transformer, the 70.7 volt transformer would not have less of a frequency response. There is no magic involved. The core is gapped for more inductance like any other single-ended audio transformer.
It is not a interleaved audio transformer, but I doubt 99% of radio audio transformers are interleaved. Interleaved transformers have superior frequency response above 8kHz. Most radios audio transformers are not audiophile quality and are lacking a tweeter. You can always buy a high-end audio transformer yourself. Some cost $500. Your choice. I will stay with the $5 audio transformer myself.
PostPosted: Aug Fri 07, 2020 10:18 pm
I've used 70.7 volt transformers as outputs for years and they work fine.
RRM
PostPosted: Aug Sat 08, 2020 5:22 pm
RRM
Thanks. I get a lot of 'it is no good' replies when I post tips.
PostPosted: Aug Mon 10, 2020 3:06 am
Well, they sound pretty good to me at the grocery store where I have 10 of them installed playing music. Seems like they would work just fine in a radio. I have used a couple that way as well.
Joel Walker
PostPosted: Aug Mon 10, 2020 3:35 am
As I said I've used them lots of times with good results. The only concern is that they aren't intended to have dc in the primary and if it's too large the core may saturate. I haven't made any measurements so I don't have any numbers for this but haven't had any problems so far.
RRM
PostPosted: Aug Mon 10, 2020 2:54 pm
RRM
Primary winding DCR measures about the same as a standard audio transformer. I recommend 10 watt rated for no more than 5 watts audio. Most tubes are 3 watts output. All 70.7 volt transformers I seen were gapped to have enough inductance for the DC current.
PostPosted: Aug Thu 13, 2020 8:01 pm
A common suggestion "in the old days"was to use a surplus 400Hz power transformer for modulating a transformer. They were plentiful but cheap since they weren't useful as power gransformers on the 60Hz line.
PostPosted: Jan Mon 11, 2021 6:20 pm
I once measured the current corresponding to core saturation on the Bogen T725 and the figure was around 15-20mA.
So the 10W audio transformer will be able to serve as a Class-A single-ended output transformer to around 1-2 Watts. Purpose built single ended output transformers are air-gapped and have a much larger core size for a given power level. Any comments?
PostPosted: Jan Mon 11, 2021 6:34 pm
devilsmist wrote:
I would imagine they have a frequency response like a wet noodle. DM
Yes, designed for Muzak and voice announcement, elevator music :roll:
PostPosted: Jan Tue 12, 2021 6:13 pm
Bogen transformers used in homebrew radios:
http://makearadio.com/misc-stuff/t-725.php
As to "wet noodle".... AM radios aren't exactly "hi-fi."
PostPosted: Jan Wed 13, 2021 3:02 am
This exact page make me aware of the Bogen T725 a while ago, however the article only mentions the use of this type of transformer as a hypothetical possibility, without ever mentioning the problem of core saturation. I think the author wasn't aware of this problem.
I'm sure this transformer will produce sound in an average AA5 as long as the plate current is kept below 10mA, which limits the output power to around 0.5W, even though the transformer could handle way more power in an AC setting.
EDIT: the push-pull arrangement is interesting (although not too much radios use a P-P audio), the two currents cancel out each other. The transformer is not symmetrical though, but I guess a decent PP amplifier could be made with a strong negative feedback.
PostPosted: Feb Mon 01, 2021 3:39 pm
Muzak worked pretty hard over the years to have good sound quality. They even had their own orchestra to play that muck.
PostPosted: Feb Mon 01, 2021 6:01 pm
Here it is! I just recommended these to the guy wanting to built the 60FX5 amplifier
https://www.ebay.com/itm/Audio-Output-T ... SwxOBdNQGj
Electronics are filled with smoke. Itā€™s my job to put the smoke back in when they fail.
Cheers,
Jay
PostPosted: Feb Mon 01, 2021 6:35 pm
Side Note: WE are not normally concerned with the DCR of an OPT---only the effective impedance, which is determined by the speaker impedance, and the transformer turns ratio. ("Impedance Ratio" is the square root of the turns ratio.)
-Mark
PostPosted: Feb Mon 01, 2021 6:40 pm
RRM
That generally happens only when someone truly believes the idea will not work, and they are able to back up their position with analysis and/or test results.
-Mark
PostPosted: Feb Sun 07, 2021 9:57 am
I've used them in push-pull mode, and they work fine. They are symmetrical with regard to number of turns each side of the CT, if you choose the taps correctly. The primary impedance was not very high but it was a good match for the triode output stage that I was using. Frequency response was pretty good, because I was using some negative feedback which helped to extend the bottom end. They were also operating well below their maximum power rating.
Users browsing this forum: wd5jfr and 7 guests
