It is currently Oct Mon 25, 2021 2:41 pm
 Post subject: Try a clip lead when soldering components with short leads
PostPosted: Jan Fri 29, 2021 2:16 am
To help position the part, and to avoid burning your fingers.
My High Voltage Capacitor Store
ARF members: PM me for 20% off
Click Here
 Post subject: Re: Try a clip lead when soldering components with short lea
PostPosted: Jan Fri 29, 2021 2:31 am
Made this years ago. I would use it to light the pilot light on my gas water heater. And use it to hold stuff to solder.
PostPosted: Jan Fri 29, 2021 2:57 am
I use a hemostat.
"It's amazing what you can accomplish when you throw safety out the window", Brent Butt
PostPosted: Jan Fri 29, 2021 5:57 am
tbone8 wrote:
I use a hemostat.
Same here.
PostPosted: Jan Fri 29, 2021 3:24 pm
I've found the hemostat to be a very handy tool, but not to lock onto a cap or resister. I like the clip on a stick idea.
Freeman
PostPosted: Jan Fri 29, 2021 3:31 pm
Hemostats have probably been my most used tool for years (both professional and hobby). There are times when clamping them shut could damage something, so I've used El Cheapo alligator clips on occasion, and putting one on a small rod like N2LXM did could come in handy at times. Certainly cheap enough to make if even for occasional use.
And here's my test lead/alligator tip. Forget those El Cheapo Chinese test leads you buy in a 10 pack (I once had 9 out of 10 read open). I used to make my own using Mueller clips and test lead wire until I ordered some from Parts Candy (advertiser on the right >>>>>>>>>). He's a member of ARF and uses quality Mueller clips and test leads that are soldered. Best part is they only cost pennies more than the ones I make myself.
John KK4ZLF
PostPosted: Jan Fri 29, 2021 3:35 pm
I use---in order of priority:
Ancient Radio shack spring clip made for the purpose
"normally closed" tweezers
hemostat
PostPosted: Jan Fri 29, 2021 7:58 pm
I'll also use a wooden clothes pin in certain situations, such as when I want to tin a lead.
PostPosted: Jan Fri 29, 2021 11:55 pm
Now THAT'S a great idea.
I use a hemostat sometimes too, but use a clip lead more often.
Click Here
PostPosted: Feb Mon 01, 2021 11:55 pm
If you can clip onto the wire side nearest the joint you can shunt some heat away from the component.
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
