It is currently Oct Sun 17, 2021 2:46 pm
 Post subject: Need a Sine Wave? Ring One Up.
PostPosted: Jun Sun 27, 2021 8:52 pm
I needed a decent 1 MHz sine wave to check calibration on a high bandwidth AF voltmeter. All my signal generators are service grade and none generate anything close to a clean waveform.
It occurred to me that I might be able to get a decent waveform by filtering out the harmonics from my EICO 324 output. I was too lazy to design a special filter so I decided to try a simple tuned circuit. I had a left over coil from a regenerative receiver project and a variable cap from the junk box so I built it up on a board and tried it out. As you can see it's really simple but it gave me a sine wave with harmonics down 45-50 db which was plenty good enough for my use.
There's plenty of room for experimentation with something like this.
RRM
