Author |
Tim Tress
Post subject: When it still won't work Posted: Jun Sat 13, 2020 2:16 pm |
Member |
Joined: Jan Thu 01, 1970 12:00 am Posts: 11797 Location: Beaver Falls, PA. USA
Many posts on the Forums involve projects that still have problems, even after component replacement. Here are some suggestions:
First, go back and check your work. It is very easy to make a wiring error, having something connected in the wrong place; we have all done it. As a former coworker, now RIP, used to say; "If the set develops another problem after you have worked on it, go back and find the problem that YOU put in". It might be as simple as a broken wire. Don't overlook anything.
Second, watch out for incorrect component substitution. It is very easy to misread a color code or capacitor marking, especially on new capacitors with a code number instead of a printed value.
Third, check the coils, speaker fields, and transformers. Open windings are common in Philco sets, but I have seen them in other makes.
Fourth, the oscilloscope is your friend. They are a big time saver on things like TV sets and communications equipment. All B+ lines should be free from any signals and ripple, and all test points should have the proper signals, at the proper amplitudes.
Lastly, check the ground connections. It's not uncommon to find that one has a high resistance, or is completely open, due to corrosion; this is particularly true of tube socket grounds. The multi-pin terminal strips on 1960s Zenith TV sets, for example, often break loose at the ends. Don't try to resolder grounds with a small iron; use something big like a Weller D550. Kit-built equipment with PC boards often rely on the board mounting screws to complete the ground connections, and they often work loose.
_________________ Tim KA3JRT
Top |
Freeman
Post subject: Re: When it still won't work Posted: Jun Sat 13, 2020 10:30 pm |
Member |
Joined: Dec Tue 23, 2014 5:51 pm Posts: 2777 Location: N. Palm Bch, Fl.
Very Good. I would add 1 more though. This should be a cut, paste, and print for some and for newbies. Your first is mine because it has burned me before. It is time consuming because you have to concentrate and compare what you see to what the schematics says. So many post here end up with component soldered to the wrong tube pin or not soldered at all. I bought my O scope for a TV horz probem and it really helped with 2 radio alignment problems. I love my scope. I would add when above fails; Start a post here with HELP. If you go through 1 to 5, you may not have to though.
Freeman
_________________ What's built by man can be fixed by man.
Top |
Zenith Royal
Post subject: Re: When it still won't work Posted: Jun Sun 14, 2020 6:59 am |
Member |
Joined: Oct Mon 02, 2017 7:53 am Posts: 1735 Location: Panama City, FL 32401
Checking current drain can tell much about how a radio is working. Recently I've been checking current drain in my radios. One Zenith Royal 50L I have works fine,or so I thought. When it showed unusually high current drain I cleaned both battery contacts. One of the wires was quite corroded. I stripped the wire then soldered it back on. Now the current was much lower and typical of what it should be.
Top |
Tim Tress
Post subject: Re: When it still won't work Posted: Jun Sun 14, 2020 11:37 am |
Member |
Another thing that I forgot to mention; just about every old radio will benefit from a careful realignment. It's not uncommon to find that the IF transformers are way out of resonance, which will greatly reduce the gain. Some multi-band radios have a definite sequence for the front-end alignment, and the instructions must be followed.
Also, don't overlook tubes as a source of trouble. Some substitutes just will not work, especially in critical front end circuits. Some tubes may refuse to oscillate under certain conditions, especially when they get a little weak; 6A7 and 6A8 tubes are notorious for this.
Audio output tubes can be mystifying trouble makers when they go gassy or get secondary emission, which can cause the plate current to "run away" . At the price of some tubes, it is easy to hunt for other problems, in hopes that the tubes aren't the cause. Any tube that has red plated is suspect. Of course, this assumes that other causes have been corrected, such as leaky coupling capacitors and biasing problems. Amplifiers with direct coupled driver circuits, such as Macintosh, are especially sensitive to tube problems.
Top |
engineer
Post subject: Re: When it still won't work Posted: Aug Mon 03, 2020 7:33 pm |
Member |
Joined: Nov Thu 09, 2006 11:24 pm Posts: 3151 Location: Thornhill, Ontario, Canada
As I've said here several times... always test the radio (or amplifier) after EACH component replacement... no optimistic batch replacements! That said, again... years ago, I refurbished a radio which then worked perfectly... I put it on the shelf with no plans except to fire it up now and again just for fun. Did this last year, it worked fine, but I decided to check what I had done close to a decade earlier... Surprise, there was an un-soldered joint on a replacement capacitor... just bent around and crimped! OMG! How on earth...? Now fixed, and all the others checked. So, I never put more than one new component in place at a time, soldering both ends! Indeed, I even solder one end before fitting the other end! Cheers, Roger
_________________ Roger Jones, Thornhill, Ontario Ontario Vintage Radio Assoc. http://www.ovra.ca
Top |
Retired Radio Man
Post subject: Re: When it still won't work Posted: Aug Tue 04, 2020 7:43 pm |
Any time I have something that doesn't work I troubleshoot. That includes things I've never seen before or something I "fixed" that didn't quite make it.
RRM
Top |
Tim Tress
Post subject: Re: When it still won't work Posted: Aug Sun 16, 2020 1:48 am |
Member |
Some folks persist in trying to get an old piece of equipment working without doing any recapping. Those of us who worked on the stuff when it was relatively new know about the problems with capacitors, and there is no easy way out. The changeover to Mylar capacitors was gradual, and some stuff from the 1960s still had a few paper capacitors; mainly in the form of "Black Beauties" . Even the "maroon drops" from the late 1950s are failing now. The early transistorized equipment is full of small electrolytic capacitors, which are often open or leaky. New capacitors are cheap, and the time spent on replacement will pay off.
Top |
Barry H Bennett
Post subject: Re: When it still won't work Posted: Sep Mon 28, 2020 12:26 pm |
Member |
Joined: Nov Wed 30, 2016 6:35 pm Posts: 12461 Location: Sunbury, Ohio 43074
My favorite is some "mylar looking" capacitor that simply isn't mylar at all. Also there were, and still are, some orange drop "look alike" caps that are just as bad. Unless you are SURE it's actually a mylar, or other film type, just replace it. New caps are quite cheap, and much higher voltage rating while being half the size of the old ones.
_________________ Preserving the hist. of electronics, one boat anchor at a time! :) https://www.bbtvtestequipment.com
Top |
jimbenedict
Post subject: Re: When it still won't work Posted: Sep Mon 28, 2020 8:51 pm |
Joined: Jan Tue 07, 2020 12:41 am Posts: 4369 Location: Belleview, FL 34420
And, finally if cannot get it working? .............................Sell it to a tech.
_________________ NAVY JACK FLAG- 'Don't Tread on Me'
Top |
John Bartley
Post subject: Re: When it still won't work Posted: Sep Mon 28, 2020 9:06 pm |
Tim Tress wrote: Some folks persist in trying to get an old piece of equipment working without doing any recapping. And ..... here's where I always feel the need to jump in. Recapping is fine, even necessary in certain circumstances, no question about that. However ......... Wholesale shotgun recapping without doing any troubleshooting is one of the most common lead-ins to "after service" problems that I have read about on these forums. These issue usually seem to happen to newbies who have been scared into wholesale recapping by the old-wives tales about certain death, fires, devastation if they don't. So .... how about - careful test - repair to make "work" in some fashion - decide about further work needs (restore, store and look at it etc) - and then move on. There is NOTHING WRONG with carefully testing a piece of electronics and doing any necessary repairs before replacing a whole pile of parts en-masse in a restoration project.
Top |
fifties
Post subject: Re: When it still won't work Posted: Sep Tue 29, 2020 12:03 am |
Member |
Joined: Jan Thu 01, 1970 12:00 am Posts: 40892 Location: SoCal, 91387
If you have tried and tried to get it to function, and it stubbornly refuses to give you that triumph, a temporary emotional satisfaction can be obtained by deftly throwing the damn thing out the window!
_________________ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\He Who Dies With The Most Radios Wins/////////////////////////
Top |
Barry H Bennett
Post subject: Re: When it still won't work Posted: Sep Tue 29, 2020 12:08 am |
Member |
Quote: - careful test - repair to make "work" in some fashion - decide about further work needs (restore, store and look at it etc) - and then move on. *put it back on the bench a month later *troubleshoot it again, because you have no clue what you already did to it *Fix it .... the end. OR *it won't be fixed. Get a 16lb sledge from the garage and pound it to dust. The end.
Top |
John Bartley
Post subject: Re: When it still won't work Posted: Sep Tue 29, 2020 12:10 am |
Barry H Bennett wrote: OR *it won't be fixed. Get a 16lb sledge from the garage and pound it to dust. The end. LOL ... does this happen to you often? Seriously .... I always fixed them to be working unless I cannot find a part or ...... in one and only one case because I could not fix it.
Top |
fifties
Post subject: Re: When it still won't work Posted: Sep Tue 29, 2020 12:11 am |
Member |
Barry H Bennett wrote: OR *it won't be fixed. Get a 16lb sledge from the garage and pound it to dust. The end. My method requires less effort...
Top |
Mr. Highlander
Post subject: Re: When it still won't work Posted: Sep Tue 29, 2020 2:02 am |
Member |
Joined: Mar Sun 22, 2020 4:56 am Posts: 2114 Location: Arvada, CO, 80004
Barry H Bennett wrote: Quote: *it won't be fixed. Get a 16lb sledge from the garage and pound it to dust. The end. Wow Barry! I never knew you were a sucker for brute force!
_________________ Electronics are filled with smoke. Itās my job to put the smoke back in when they fail. Cheers, Jay
Top |
DenisN
Post subject: Re: When it still won't work Posted: Sep Tue 29, 2020 5:11 pm |
Joined: Oct Sun 18, 2015 1:49 am Posts: 435 Location: San Angelo, TX
My two cents worth. If you remove some component, MAKE A DRAWING of it and connection points! Pictures are good, but I still make drawings because wires crossing under each other get lost. Denis
Top |
Barry H Bennett
Post subject: Re: When it still won't work Posted: Sep Tue 29, 2020 8:32 pm |
Member |
John Bartley wrote: Barry H Bennett wrote: OR *it won't be fixed. Get a 16lb sledge from the garage and pound it to dust. The end. LOL ... does this happen to you often? In the fiery days of my youth, it used to. I lost several auto repair tools hurled into orbit, apparently. But I"m much better now.
Top |
John Bartley
Post subject: Re: When it still won't work Posted: Sep Tue 29, 2020 10:48 pm |
Barry H Bennett wrote: John Bartley wrote: Barry H Bennett wrote: OR *it won't be fixed. Get a 16lb sledge from the garage and pound it to dust. The end. LOL ... does this happen to you often? In the fiery days of my youth, it used to. I lost several auto repair tools hurled into orbit, apparently. But I"m much better now.  LOL ... I sympathise. About twenty some years ago I needed my first bifocals. I allowed myself to be talked into a pair of reading glasses because my long distance vision was pretty good. I'm not easily irritated and never have been, but those reading glasses did something to me ... perched on my nose .. always there ... just underneath my distance vision line of sight ... sllding down my nose when I perspired ..... arrghhh !! They died on the shop floor under a 2-lb sledge and I went to buy full bifocals ... and loved them from the first second I slid them on  ...
Top |
Tim Tress
Post subject: Re: When it still won't work Posted: Sep Wed 30, 2020 6:51 pm |
Member |
Besides filter capacitors, the one which should be replaced is the coupling capacitor to the output tube grid (or grids, if it has push-pull outputs). This will be enough to verify the operation, before more work is done. It's not uncommon to find more than one problem.
Top |
John Bartley
Post subject: Re: When it still won't work Posted: Sep Wed 30, 2020 7:10 pm |
Tim Tress wrote: Besides filter capacitors, the one which should be replaced is the coupling capacitor to the output tube grid (or grids, if it has push-pull outputs). This will be enough to verify the operation, before more work is done. It's not uncommon to find more than one problem. I can get on board with this. It's sensible.
Top |
Who is online |
Users browsing this forum: Mr Peabody and 4 guests |
