Removing the "Newer-Style" General Radio Knobs
Back in the '20s and '30s radio magazines ran tips from readers. Here's the Forum version; post your ideas and radio fixes here to share with the rest of us. Ads are not permitted.
Post Reply
diskcopy
Mar Tue 16, 2021 11:23 pm
Pacific, Missouri
Contact:
Post by diskcopy »
The newer General Radio knobs (without a set screw) are held on control shafts by a spring. Removing them can be a pain in the you-know-what. I found that an easy way to remove them is to shimmy a plastic card, such as a credit card, under the side of the knob that doesn't have the spring. The card can then be rotated under the base of the knob to put pressure directly under the spring and relaese it.
To reach the Truth it is necessary...to put everything in doubt so far as possible
- Descartes
Mike Toon
Jan Thu 01, 1970 12:00 am
Burbank CA
Re: Removing the "Newer-Style" General Radio Knobs
Post by Mike Toon »
You can use a comb too because it has a taper.
Post Reply
