It is currently Nov Tue 24, 2020 2:28 am
 Post subject: Collins KWM2A? On The Bay
PostPosted: Oct Tue 20, 2020 7:00 pm
I stumbled across this KWM2A on the bay but the picture of the rear of the unit looks like it is missing a lot of connections.
Maybe it is in the wrong case.
Opinions please.
https://www.ebay.com/itm/402495401442
 Post subject: Re: Collins KWM2A? On The Bay
PostPosted: Oct Tue 20, 2020 10:37 pm
What you are seeing is the back of the PM-2 power supply bolted to the back of the KWM2a. https://www.ebay.com/itm/Colllins-PM-2- ... Sw0aNfSrb3
https://www.universal-radio.com/catalog/hamhf/pm2.html
The KWM2 series could be used with this bolt-on supply or a completely separate supply (516F2, https://www.ebay.com/p/1101476214 ) as was done with most other transceivers.
Curtis Eickerman
PostPosted: Oct Wed 21, 2020 1:20 am
Thanks Curtis, I made a low ball offer on it as he sent me some pictures of the inside and it is a total mess.
Thanks as I would never have guessed that that was the power supply.
PostPosted: Oct Wed 21, 2020 2:38 am
Well Curtis, he accepted my offer and I will own a Collins KWM2A. I have always wanted one but could never afford one. Here are some of the pictures he sent me of the inside. Looks like the fun begins again. I need to start collecting KWM2A manuals.
PostPosted: Oct Wed 21, 2020 1:21 pm
I hate to say it, but you bought a pig in a poke from a zero feedback seller. Fla. location might explain all the corrosion. Good luck.
PostPosted: Oct Wed 21, 2020 1:23 pm
Well, good luck. Just an idle query on my part, in this day and age how on earth does someone take pictures that are that bad? I've seen much better pictures done with a pin-hole camera.
Curtis Eickerman
PostPosted: Oct Wed 21, 2020 4:35 pm
THE BAD PICTURES WERE MY FAULT AS I TOOK THE SMALL PICTURES HE SENT ME ON THE BAY AND TRIED TO ENLARGE THEM. HERE IS A BETTER SET. I AM LOOKING FORWARD TO THE PROJECT.
PostPosted: Oct Wed 21, 2020 7:31 pm
Congratulations on getting a set you've always wanted. Is that corrosion or dirt or both?
Mike Cornell - KC2OSO
PostPosted: Oct Wed 21, 2020 10:41 pm
Looks like a lot of cleaning will need to be done on it.I used one many years ago they are very nice and sound great when everything is in order.Found it to be easy to use and dail readout was very close too.Nice light set to work on tho the PS is heavy.Manuals should be easy to fiind.Ebay sometimes has parts sets come up a cheap prices.Good luck with it.Angelo :D
Be happy ,enjoy life as its so short!
PostPosted: Oct Thu 22, 2020 12:56 am
Much better pictures. With those it is clearly mostly just dust and should clean up pretty easily. Maybe just take it outside and blow most of it off with an air compressor or canned air. It also looks like everything was dry, which is a good sign. Clearly it will take a little work, but probably not too bad.
Congratulations,
Curtis Eickerman
PostPosted: Oct Thu 22, 2020 1:26 am
I should be getting it next week. I just hope it comes when my wife is out.
PostPosted: Oct Thu 22, 2020 1:31 am
That's a dangerous game you're playing there sir. :)
Post New Topic Post Reply  [ 12 posts ]  Moderator: Lou deGonzague
Users browsing this forum: Mr. Highlander and 6 guests
