It is currently Feb Mon 24, 2020 6:43 pm
 Post subject: AM Transmitter
PostPosted: Feb Sun 02, 2020 4:44 am
Has anyone been able to find an authentic 1920s AM single 01A tube transmitter schematic?
 Post subject: Re: AM Transmitter
PostPosted: Feb Sun 02, 2020 6:16 am
Two 01As for modulation...
viewtopic.php?p=2374878#p2374878
PostPosted: Feb Thu 13, 2020 9:52 pm
Interesting, but would it be possible with one tube? The following photo is from:
Project Gutenberg's The Radio Amateur's Hand Book, by A. Frederick Collins
I've built this one before, but have had no luck. Possibly I made a minor mistake...Has anyone else tried something similar?
PostPosted: Feb Thu 13, 2020 10:58 pm
That circuit requires a carbon microphone. It won't work with any other kind.
PostPosted: Feb Thu 13, 2020 10:59 pm
G. Brook, you are probably aware that that "lamp socket" connection is for the old DC house wiring.
PostPosted: Feb Thu 13, 2020 11:49 pm
Yes I’m already aware of the needed power supply. I’m just wondering if a schematic as such would perform properly?
PostPosted: Feb Fri 14, 2020 2:15 am
It depends on what you mean by properly. It can probably be made to oscillate. If you can find a carbon mike and shout into it, then you can probably transmit some kind of speech to a nearby radio.
If your goal is to transmit music of reasonable fidelity, then no, it won't do that. Not without more tubes.
PostPosted: Feb Fri 14, 2020 4:00 am
Connecting the microphone in series with the antenna requires a mike that can dissipate the needed amount of power. Back when that method was the only way to go, they had water cooled microphones. That wouldn't be necessary with a 01A oscillator but it is still something to consider. A 01A might be capable of a watt or two of RF.
PostPosted: Feb Fri 14, 2020 12:44 pm
Hmmm.... Just guessing, I would have to look up the data sheet, but I think the anode resistance of the 01A is about 10k, and as I recall in a class A audio amp you could only squeeze 30 to 80mW out of it if that. I'm not sure how an 01A could produce an RF output power of anything like 1 watt, let alone 2 watts. It might be possible to get a few hundred mW , with two of them, in class B push pull, I would have to look that up.
PostPosted: Feb Sat 15, 2020 7:39 am
You would operate it in class C which is a lot more efficient than class A. The 1 or 2 watts was a guess.
PostPosted: Feb Tue 18, 2020 2:54 am
In practice though its not hugely more even in class C because to get any reasonable power output is a compromise in impedance matching, so in general the efficiency, in practice in class A might be 30%, class B perhaps 50% and class C about 70% (even though theoretically 98% might be possible). So I still cannot see how anywhere near 1W could be attained from an 01A even in class C, maybe a few hundred mW. Still, that would be ok for a short range AM transmitter, but it would require a good modulator.
For my own short range AM MW band transmitters I have moved to linear class AB push pull output amplifiers (really just class B biased out of cross over distortion) and modulate the carrier before the output stage with a precision amplitude modulator, to avoid the distortion that occurs modulating at the output stage.
Users browsing this forum: No registered users and 16 guests
