It is currently Nov Sun 29, 2020 1:40 pm
 Post subject: Voltage regulator design
PostPosted: Oct Wed 28, 2020 6:48 pm
I have a torroidal transformer that has two 30 volt 4.17A windings which unloaded produce 42.42Vdc peak.
I need a + and - 35Vdc 1.5A regulated supply for a project.
I actually needed +/- 35V 3A, but it would be easier to do two separate +/- 35V 1.5A supplies.
I am building the circuit in an old car audio amp chassis that is all aluminum so I have plenty of heatsinking.
I prefer the regulators be linear if at all possible and TO-220 case style as those are easier to mount.
Current will not normally be 1.5A, but wanted a little head room.
Each output will have a 1.5A fast blow fuse.
Will also need a 12 volt regulated supply at a max of 500mA. I suppose a higher voltage version of the 7812 would work for that.
 Post subject: Re: Voltage regulator design
PostPosted: Oct Wed 28, 2020 10:17 pm
You might find an LDO (low dropout) regulator, but the high input voltage is perhaps an issue.
What AC voltage is produced when the transformer is loaded to about 3 Amps. You won't have much headroom for regulation.
PostPosted: Oct Wed 28, 2020 10:20 pm
Hadn't thought about that.
Might see if I can find what the spec is on the transformer.
EDIT:
Here's the transformer.
https://www.parts-express.com/avel-lind ... r--122-630
Typical regulation 6.4
Max VA rating
Efficiency 93.2%
Copper loss 16.6W
Iron loss 1.6W
So the transformer is rated for a 115/230Vac input.
Doing the math I get an output of 31.307Vrms on each secondary for an input of 120Vac.
I would then have an unloaded voltage of 44.268Vdc.
Main filter caps after the rectifier would be at least 10,00uF 50V.
PostPosted: Oct Thu 29, 2020 8:04 pm
as i say in another topic you need something like this :
https://powersupply33.com/0-30v-5a-adju ... it-diagram
https://aurelsoft.ucoz.com
PostPosted: Oct Thu 29, 2020 8:15 pm
Interesting circuit.
Only problem is mounting the TO-3 transistors.
PostPosted: Oct Sat 31, 2020 4:53 am
The LM338 is a possible solution and it's available in TO-220 albeit with the tab terminal being Vout. It is capable of 35V output. Bear in mind the thermal consideration in a linear pass regulator is (Vin - Vout) * Ipass. For Vin = 42V, Vout = 35V, and Ipass = 1.5A, that's 10.5W which is doable with clean planar surfaces and some good thermal compound.
There exist LM338 based module solutions on Banggood (as of this writing) for $16 with shipping included. These have a fan bolted to a TO-3 + heatsink. Also as of this writing the LM338T (TO-220) is 2.11USD @ Mouser.
Depending on your willingness to build/hack, the classic pass regulator is a simple discrete design if one omits current sensing/limiting and only a bit more complicated if you don't. I wouldn't omit current sensing/limiting at the requested max current. The failure mode on power BJTs can be a collector to emitter short.
As someone said so elegantly elsewhere, this is power supply design. It is well-documented about the web with many examples and eminently doable as you seem to already be doing.
One note of caution if I may, do double check circuits involving bridge rectifiers. People sometimes inadvertently include a sneak path, particularly to ground, especially when multiple such circuits are employed.
Coop, aa1ww
PostPosted: Oct Sat 31, 2020 5:14 am
I'm assuming that's a positive regulator.
Is there a negative version?
EDIT:
Concerning transistors I have a pair of 2SA1941 and a pair of 2SC5198 I could use to either make a + and - regulator for the whole circuit or individual + and - regulators for each circuit. Basically it is two circuits requiring a +/- 35 volt supply with each individual circuit drawing a max of 1.3A on the + and on the - supply.
Doing two individual +/- regulators would be better as it would keep the regulators cooler, but is more complicated to do.
Current limiting is not necessary as each output will have a 1.5 amp fast blow fuse going to each circuit.
2SA1941
https://datasheetspdf.com/pdf-file/7372 ... /2SA1941/1
2SC5198
https://www.mouser.com/catalog/specshee ... 101102.pdf
So I suppose I could use an adjustable regulator and use those transistors as pass transistors.
EDIT:
Perhaps it would be possible to use those transistors with this circuit modified to handle a max of 50Vdc input and put out 35Vdc.
Taken from here
https://www.ti.com/lit/ds/snvs778e/snvs ... e.com%252F
Users browsing this forum: battery-maker and 3 guests
