It is currently Nov Mon 23, 2020 11:09 pm
 Post subject: 6GY6 transmitter in a computer power supply box
PostPosted: Nov Sat 14, 2020 10:42 pm
Ever since I saw the plans for a transmitter using a dual control pentode I knew I had to build one. I settled on the 6GY6 version with the 6BK7 preamp/tunable oscillator version. I decided to build mine inside an old computer power supply. I did take quite a bit of liberty with the audio caps, increasing them in size to pass 20Hz as I wanted this to double as a piece of test equipment to check frequency response of various radios. I find it actually passes down to 15Hz fairly well. C2 was increased from .01 to .05; C3 was increased from 4.7 to 100uF as that's what I had on hand. Calculations showed I could have gotten away with 68uF. C4 also took a whopping jump from .05 to 1.0uF. The "chassis" is a piece of double-sided circuit board.
Because this is a tube project I decided I also wanted a tube rectifier so I got rid of the sand state diode and used a 6X4. I put .001 from cathode to each plate. Power supply caps were 22u input (tube rectifiers are a bit more limited in what they can handle for input caps and 47u was kept as the output section. If I had to do it over I'd probably have used 33u input and 68u output, but these values still worked. Transformer is a Hammond 261G6. It's overkill for this projecxt but it was the only one in the plate voltage range which had the filament current I needed.
Photos and commentary-
File comment: Here's the box stripped of the main board leaving the fan and RF filtering. In the corners I added some 12mm standoffs I got from Tube Depot so there'd be room under the board for components. Also a fuse holder, a small turret terminal for attaching the antenna on the outside, plus the pot and RCA jacks.
File comment: Tuning cap and tube sockets. Also used a stud mount cap for the 6GY6 cathode bypass that I had around forever. I think I got that in one of those old Polypaks when I was still in elementary school, ca. 1970.
File comment: Originally drilled the hole for the stud mount cap on the wrong side. Turned out to be fortuitous, though. Was able to poke another cap through there later.
File comment: The pieces of tape and nail-polish masked areas were to aid etching some pads and blank areas free of copper.
File comment: The finished pads- the square for the common high voltage connection; to the left is for the cathode audio bypass cap. The + lead goes through the left hole to the tube socket.
File comment: Checking for fit.
File comment: Normally I don't like to add sand to my tube projects, but given this would be inside a computer case I decided the fan should be operating and so I built this little circuit board for DC to power it and the LED
File comment: Finished fan power supply
File comment: More components added. Note- tubes are not the ones that belong there; these are just placeholders to give me an idea of what it will be when finished. Rectifier is a dud 35W4.
File comment: Underside around the 6GY6. More in the next post.
 Post subject: Re: 6GY6 transmitter in a computer power supply box
PostPosted: Nov Sat 14, 2020 11:06 pm
Continued from the above post- photos and commentary.
File comment: Components around the 6BK7. The schematic didn't show the shield on pin 9 so I originally tied the oscillator output cap and coax to it. After checking a tube manual I grounded that pin and made the cap/coax a flying (not tied to a terminal) connection. It's rigid enough that jarring the unit isn't a problem. On the oscillator coil I used a couple short pieces of 18 ga. wire, one side ground on the active winding and one side of the unused winding to ground as well. Made the coil very rigid mechanically as well.
File comment: My initial tests were using a Heathkit HV power supply. Here is its first test using the transformer mounted in the box. Also checking resistors to try and get 3v on the cathode. I ditched the fixed resistor on the advice of forum member 35Z5 and used a 220 ohm resistor in series with a parallel combo of a 1.5k fixed resistor and a 500 ohm pot.
File comment: Checking the fit in the box
File comment: Trimming the transformer leads proved to be crucial to good fit. Here they're still a tad too long.
File comment: Now it fits better.
File comment: Another angle
File comment: Top cover on. Knob on tuning cap was borrowed from a parts set
File comment: Looking at the tubes from the top. The rectifier is visible in the back when looking at it but didn't show up in the photo.
File comment: The back side. You can see the rectifier through the whirling fan blades but the stroboscopic action of the flash makes it look stalled and blocks the view. Keeping good air flow through the box proved to be good for keeping the transmitter from drifting more than it might during warmup.
PostPosted: Nov Wed 18, 2020 4:00 am
That's a great build, nice attention to circuit detail.
Reason I didn't show 6BK7 shield, program didn't include one in the dual triode choices. I've seen 12AV7 with shield inside but not connected as pin 9 is heater CT. Other than shield & heater configuration, 6BK7 & 12AV7 are same tube.
PostPosted: Nov Thu 19, 2020 11:58 pm
I happened to be thumbing through a GE tube manual while I was constructing it and it showed the shield on the base diagram and when I looked between the sections of the actual tube, sure enough there it was which is why I knew to change it. Not a biggie, though, as I know I've overlooked small stuff like that myself. It's a great design otherwise and sure beats every other "part-15" transmitter I've ever built.
The FCC has a part-15 band in a section of the 22m band (13.5MHz region) where you can run a whole watt. I'd love to build a companion transmitter for that frequency. I'd be more willing to opt for some sort of frequency control up there since a free-running oscillator tends to wander around. My build above drifts +/- 150Hz even after it's warmed up though it does stay centered on where it's tuned.
Scott Todd
PostPosted: Nov Fri 20, 2020 12:39 am
Very nice build.
PostPosted: Nov Sun 22, 2020 2:46 am
Thanks for the kind words. I wanted to do something creative and that seemed to be the most compact way of doing it. I do like the ones where the tubes are standing out in the open too, though.
I ran it again this afternoon, and as I was doing so I dug out an old Dorrough 310 audio processor. While it's not an antique per se, in terms of radio technology it is still considered pretty primitive with early ICs and discrete components. I did it because the transmitter really does need some way of controlling modulation to prevent carrier pinch-off on negative peaks, otherwise you have to run the modulation down a bit so as not to run the risk. It's pretty obvious when it does that. Now it's blowing a hole in the dial when I have it on. This transmitter is a lot of FUN!
Scott Todd
PostPosted: Nov Sun 22, 2020 4:43 pm
Scott Todd
With it used as test equipment, a enclosed design is no doubt the best.
I'm running a 6GY6 built in RCA UHF converter, BUT because it now has a octal to 7 pin adaptor to use 6888, I can't get it back into it's case. I should install octal socket, but works so well in it's duct tape & bailing wire configuration, I'm almost afraid to mess with it.
For fun factor, thank Norm Leal for designing the original 6888 this transmitter is based upon. You've no doubt improved upon original, my skill set is mostly trial & error. One of these days I'll probably use your cap values.
I use Stereo tool as audio processor, good at maintaining constant levels. Over the last dozen years I've sent four or five Win XP computers to their grave that ran 24/7 as audio servers. Overall had more computer failure than xmitter.
PostPosted: Nov Mon 23, 2020 9:54 pm
Very nice design and construction. Would you be willing to share the schematic for this? Thank you. Mike
Users browsing this forum: Mike Toon and 5 guests
