It is currently Jan Fri 21, 2022 1:48 pm
 Post subject: Allied knight crystal radio
PostPosted: Jan Fri 14, 2022 8:10 pm
I am assuming I can remove the tap, and use a slider to tune the coil.
Andrew
 Post subject: Re: Allied knight crystal radio
PostPosted: Jan Fri 14, 2022 10:14 pm
If you're referring to the secondary tap between the 30 & 80 turns, that's not really a tuning tap, it's to better match the crystal load to the tuned circuit (the tapped coil & variable cap).
PostPosted: Jan Fri 14, 2022 10:28 pm
I agree about the impedance matching comment. Knight probably designed around a "sweet spot." If you want to use a slider, you will have to remove insulation from the coil wires. Careful not to short adjacent turns.
Years ago I built a double slider; one side tunes the frequency, the other side tunes for best match to the detector. In practice, they both interact and I never liked the slider results. A loose coupler is better.
PostPosted: Jan Fri 14, 2022 11:27 pm
looking to build this one, not sure how to connect the variable capacitor.
https://www.youtube.com/watch?v=_XI8OWIqShk
Andrew
PostPosted: Jan Sat 15, 2022 1:23 am
Hard to say what they did exactly, from looking at the poor images in the video. They might have tapped the coil but more likely if's a simple continuous coil with slider & the var capacitor across the 'active' turns selected by the slider.
PostPosted: Jan Sat 15, 2022 3:26 am
Andrew
PostPosted: Jan Sat 15, 2022 6:39 am
You can tune a radio by either adjusting the inductance or capacitance (or sometimes both).
In the case of this circuit, the coil tap should remain fixed, as it's apparently located at the best spot for reception, and the variable capacitor used for tuning stations.
PostPosted: Jan Sat 15, 2022 5:00 pm
Do you have the allied crystal radio or going to make one from scratch . If your going to make one use a matching transfomer and a benny and the tap on the coil is not necessary and will give you better sensitivity and selectivity . The benny and matching transfomer can be used on any crystal radio .
You may want to contact ARF member krystallo he lives near you ad he is big into crystal radios
Mark
PG-18-23909
PostPosted: Jan Sat 15, 2022 10:40 pm
mrx,
I see you are pursuing this crystal radio build in more that one thread. I think the rule here is that discussions of a device or the like are supposed to be consolidated into one thread. It gets better & clearer help for you if the people trying to help can see all of the questions & changes you are considering.
