It is currently Nov Sat 26, 2022 3:35 pm
 Post subject: Led/Tube homebrew?
PostPosted: Nov Mon 21, 2022 7:11 pm
I've built radios with type 30 or 1U4 tubes and never liked the idea that the filament is usually invisible when "illuminated".
This gentleman gave me an idea. https://www.theradioboard.org/forum/other-electronic-projects/12au7-mini-mini-watter
Seems easy to do with all-glass miniature tubes. I wonder if anyone has tried it with octals, like the 30 or 1G4 types? Seems like the bottom of the locating base could be drilled or cut away with a Dremel and an LED mounted in the socket in close proximity. I would use orange LEDs; the blue are kind of spooky. Although, one could use a blue and power it from the B+ current in a way that modulates the light with audio peaks. Just like a mercury vapor rectifier.
I don't want it to be merely a "display" tube; I want it to function in a radio.
 Post subject: Re: Led/Tube homebrew?
PostPosted: Nov Mon 21, 2022 10:17 pm
Why would this be desirable? Unless we're making a night-light.
The LED sure doesn't prove the tube filament is working.
This seems like trying to gild a lily, or impress someone who knows nothing about tubes.
PostPosted: Nov Mon 21, 2022 11:48 pm
I've seen some commercial units with that feature. For some reason they prefer blue LEDs. I like glows.
PostPosted: Nov Tue 22, 2022 1:46 am
WHY????
So it has the nostalgic glow of warm tube filament!
PostPosted: Nov Tue 22, 2022 2:27 am
But it's NOT.
It's the wrong color.
It's in the wrong place.
It doesn't get warm at all.
It's an unnatural abomination and should be banned!!
:roll:
PostPosted: Nov Tue 22, 2022 3:06 am
Amen, Brother!
Anyone who misuses a vacuum tube should expect the Spanish Inquisition.
PostPosted: Nov Tue 22, 2022 4:43 am
I think that the newer Mcintosh amps use that feature! :D
PostPosted: Nov Tue 22, 2022 6:41 am
Why not just use a 6J5GT or 6C4 tube that naturally light up?
Jim Mueller
PostPosted: Nov Tue 22, 2022 4:03 pm
As a youth, I grew up with the "Boys First Book of Radio" (Alfred Morgan). He used tubes that operated from filament batteries so that a power supply transformer and 120V AC connections weren't needed.
Sure you can use a 6V triode, but that complicates the power requirements. LEDs are perfect for battery radios.
PostPosted: Nov Tue 22, 2022 4:52 pm
NOBODY expects the Spammish Repetition !
Rich : You are hereby sentenced to spend one hour in the comfy chair and to be severely poked with the soft cushions.
PostPosted: Nov Tue 22, 2022 6:31 pm
100 lashes with a wet noodle :lol:
There has been recent posting(s) of the effect of photons on gas tubes. I have seen this effect myself from a an overhead fluorescent lamp (40w tubes)on a functioning 200a detector triode. A raspy hum. Now that is on a gas tube with a clear envelope, close the cover of the radio and the noise stops or shut the darn light off :roll:
That, makes me think if noises or the from "modulation" were to be impressed on the LED and inconsideration if the LED is a fast responsive type such as used in computer camera. What would be the effect on the electron stream and could this be used to any benefit such a signal injection or mixing?
Chas
PostPosted: Nov Tue 22, 2022 8:11 pm
The fluorescent tube problem is likely caused by "hash" due to the Hg ionizing and de-ionizing in the fluorescent tube. 83 mercury rectifiers have similar issues.
Interesting about using a fast LED, probably UV to modulate the electron stream.
I have used laser pointers to ignite old NE-2 lamps that won't fire in a normal circuit. Had an indicator light on an outdoor box that worked only in the daytime. Using a laser pointer, I could trigger it at night.
PostPosted: Nov Thu 24, 2022 10:57 am
I can picture a vacuum tube aficionado seeing that tube for the first time and freaking out, "OMG that tube is red plating like a son of a gun! " But wait, I see the plate isn't connected.
I have a few 5mm led's most likely intended for some sort of display effects. They cycle through a bunch of colors and flashing routines and then repeats them. That would really get 'em going if one was mounted at the base of glass envelope tube. Might even be hyped up as the latest exotic snake oil mod/upgrade.
PostPosted: Nov Sat 26, 2022 1:28 am
Instead of the switch, which doesn't look vintage, he should put a Morse code keyer on there.
"In a crowded room or a boring meeting, communicate silently with friends that know code!"
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Nov Sat 26, 2022 1:47 am
Found this at a local Pharmacy. TRF AM and FM.
Users browsing this forum: Vintage A and 1 guest
