Airedale wrote:
Well, yes & no...
What you need to know is what is the maximum capacity of the tuning condenser... From the figure in pf or mmf (pico farads or micro-micro farads). The coil that will work with that condenser can be determined. At least a start, as one must make a or buy a coil form for the 4-pin socket. Then a fixed diameter of the form will be known. Calculations made base on that coil form diameter and the tuning condenser to arrive at an approximate coil to wind and what size wire. The Feedback winding can be estimated at 10 to 25% of the main winding.
If you want to guess on the windings, the number, diameter and turns can be taken from any of the many manufactured plug-in coils that were once offered from the 20's to the 60's.
Search World Radio History for 20's magazine articles based on a one tube radio in the 20's.
https://www.worldradiohistory.com/hd2/I ... search.cgiThe reason to search earlier magazines is the apparent maximum capacity of your tuner appears to be 500pf, modern vales are 365pf...
Your $16 for a China coil would be better spent getting an LCR meter ask advice from ARF members what is a better model...
I use older instruments so I do not have a pocket meter...
GL
