It is currently Oct Mon 21, 2019 3:10 am
Post New Topic Post Reply  [ 51 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: My new Magic Eye
PostPosted: Feb Sat 10, 2018 2:04 am
WOw, wow! another interesting solution!!!
Is full set-up data provided?
Is there a U.S. vendor? I'm concerned about any unexpected import duties into U.S....
I have a French Monopole receiver, of which I don't have the model number handy. It is a stark, large, art deco table top in a blond finish. It will need a rim lock eye tube, $$$ I'm afraid. Such a solution may be feasible as the eye tube mount is in an open unobstructed area...
Besides it is a French product, I like the match :)
Chas
PostPosted: Feb Sat 10, 2018 2:13 am
Chas
Yes, complete datas and set-up instructions are provided (but not sure they are also available in english). I don't think there is a U.S vendor but the seller is also on the well-know auction site and ships worldwide.
Search for: FREQUENCEMETRE - VOLTMETRE - OEIL MAGIQUE INDICATEUR D' ACCORD
PostPosted: Feb Sat 10, 2018 3:59 am
Tubologic wrote:
Actual size is about the same as the EM34 target and of course the pixellisation can't be seen at normal viewing distance.
This is HUGE, the front size is 31 x 41mm, forget about the back size. How can it be "about the same size as EM34", the EM34 tube diameter is 25mm?
PostPosted: Feb Sat 10, 2018 4:23 am
I meant the display size. The complete module external size is of course larger than a EM34, but the displayed pattern on the screen match the target size of an EM34 (25 mm). This means that (unlike your prototype) it can not be mounted in some radios where space around the eye tube is limited. So far I didn't had any problems as on most European table radios the eye tube is mounted on the speaker board with plenty of space around. Visually speaking, it's the best (solid state) substitution I found so far, but nothing is perfect...
PostPosted: Feb Sat 10, 2018 4:17 pm
While the other solution looks good I myself like the simpler one the OP provided.
Now the other one would be good if one wanted to know the other info it provides.
PostPosted: Sep Sun 30, 2018 9:00 pm
upsss wrote:
I may be wrong but I am not aware of radios without a power transformer and with a magic eye tube.
there were a few. When you find one, you can usually use a type 6N5 aka 6AB5 tube. They are rated for a lower B+ and are cheaper than the other eye tubes. I have many in stock but rarely use them.
Mark Oppat
PostPosted: Sep Sun 30, 2018 10:52 pm
Just off the top of my head, the Freed Eisemann FM-40 is one of them.
15 tubes plus a ballast.
http://www.nostalgiaair.org/pagesbymode ... 006434.pdf
PostPosted: Oct Mon 01, 2018 2:49 am
A 6AB5 or 6N5 will not replace 6E5 or 6U5 in a series wired filament radio. 6AB5 draws 150 ma. The others 300 ma. A resistor could be added across the filament to bring current up to 300 ma.
PostPosted: Feb Tue 05, 2019 10:32 pm
Yes on the defuser. But very cool
PostPosted: Mar Wed 20, 2019 9:26 pm
I really like the lm3914-15-16 chips. When the next LED turns on, it does so gradualy, so when used in dot mode, there isn’t a distinct step from one being on to the next. I supposed in some instances either/or on/off display might be a nice feature, but these chips were designed to make a substitute for an analog meter, and do an admirable job of it.
PostPosted: May Sun 12, 2019 5:25 pm
upsss wrote:
... Don't forget that a magic eye tube is good only for about 1000 hours.
I love eye-tube radios, but I still call these tubes very expensive pilot lights!
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
Users browsing this forum: No registered users and 14 guests
