It is currently Oct Mon 14, 2019 10:49 am
 Post subject: AM Transmitter schematic
PostPosted: Apr Sun 21, 2019 7:09 pm
Hello, I want to build a household tube transmitter for the fun of it. I have an SS Tran 3000 but I want to challenge myself and make one with tubes. This will be for local broadcast (as in my house) 25-30 YARDS would be plenty.
 Post subject: Re: AM Transmitter schematic
PostPosted: Apr Sun 21, 2019 9:53 pm
Will this do ?
PostPosted: Apr Sun 21, 2019 11:01 pm
T'bird - What are the specs on the coil, and what type of antenna does it require? CharlesD
PostPosted: Apr Mon 22, 2019 1:17 am
There are much better performing transmitters than the one posted by T bird. Do a search in this section and you will come up with a couple of very good designs.
PostPosted: Apr Mon 22, 2019 11:43 am
Hello Jim
https://www.vintage-radio.net/forum/sho ... hp?t=26009
Have a read here. I built mine maybe a dozen years ago and its worked fine all that time. Usual problems with Hum from intermodulation. If you feel like making it then give me an e-mail and I will send you my tips on minimising this.
Heres some comparison to an SStran that a friend had . Radio in use was a top quality HMV radiogram.
Once I had sorted the MATE out for mains hum / intermodulation it sounds fine to me, I'm not convinced a little FM will produce objectionable distortion.
Side by side comparisons are never easy, and the MATE takes time to warm up, but changing from one to the other I think you would have to be very discerning to tell whether you were listening to it or the SStran in a blind test.
Gary
PostPosted: Apr Mon 22, 2019 12:57 pm
Antenna is a wire around 4 to five feet. Coil is here.
https://www.tubesandmore.com/products/coil-oscillator
PostPosted: Apr Mon 22, 2019 2:06 pm
Rick McWhorter has a schematic and instructions that can be found at this site for what looks like a pretty awesome transmitter:
http://www.richardmcwhorter.com/AM_Transmitter/
linguam Latinam apparere facit nos magis intelligentes
John R...
PostPosted: Apr Mon 22, 2019 9:09 pm
Doubtful that any of the transmitters at those posted links could hold a candle to Norm's simple 6888 transmitter:
viewtopic.php?f=12&t=63310
Also, check out 35Z5's 6GY6 transmitters:
viewtopic.php?t=68236
PostPosted: Apr Tue 23, 2019 1:25 am
LOL, that thing's mostly for looks & has a hot tuning cap to boot.
The 6888, 6GY6 and other dual control pentodes modulate with far more depth than anything with a remote cutoff pentagrid amp.
PostPosted: Apr Wed 24, 2019 1:14 am
There is also the 12CS6 version.
PostPosted: Apr Sat 27, 2019 7:59 pm
Don't even consider building one like this without modifications for safety:
Note that the audio input jack is connected directly to the AC line.
If you want to use this circuit, add a proper power transformer, or an AC line isolation transformer.
Yes, 120V usually won't kill you, but sometimes it does. There are quite a few such circuits floating around; this isn't the only one. Some have capacitors in series with the audio input common connection. This may keep you alive, but introduces a good chance for lots of hum.
The remote cutoff 6SA7 is not your best choice for an oscillator / modulator tube, either. The remote cutoff signal grid characteristic introduces audio distortion. There's a good selection of $1.00 tubes that will do better. If you do use a pentagrid tube, it might be worthwhile to separate the oscillator and modulator functions, using a second tuned circuit to couple the plate to your antenna.
Study the linked threads for lots of ideas.
Ted
PostPosted: May Fri 10, 2019 1:16 pm
Just wondering Tim, did you build one? If so, which one?
John R...
PostPosted: May Thu 16, 2019 7:44 pm
Tim, Ted or Tom?
