It is currently Jul Thu 18, 2019 7:56 am
 Post subject: Remote tuner for a loop antenna
PostPosted: May Thu 09, 2019 7:43 am
I have a loop which tunes 40m and 80m and have been contemplating a method to remotely control the 700pf variable capacitor. A friend told me of a solid state devise that changes capacitance as the controlling voltage changes. I've never heard of anything like this. Do you think it might have the range of my current capacitor? I have a gut feeling that answer is NO. I could do some research on this if I knew the formal name of this thing. Thanks for furthering my education on this subject.
 Post subject: Re: Remote tuner for a loop antenna
PostPosted: May Thu 09, 2019 11:38 am
Varactor diode---also sometimes called a "varicap"
https://www.mouser.com/Semiconductors/D ... _/N-ax1mn/
Use their filtering tools to find the desired capacitance and other parameters
-Mark
PostPosted: May Thu 09, 2019 3:13 pm
I don't think varactors usually go that high in pF but I could be wrong. Is the antenna for receive only? That makes a difference. What type of cap are you using now, plate cap, vacuum cap? How far is the variable cap from the shack? There are all sorts of ways to attach a motor, stepper motor, servo but what is best or easiest depends on the situation.
PostPosted: May Thu 09, 2019 6:55 pm
Varactors were made with >300 pF capacitance to use in tuning low cost solid state AM radios.
http://www.kitsandparts.com/MVAM109.pdf
PostPosted: May Thu 09, 2019 7:49 pm
You can use varactors in parallel, but your range is limited unless you use series/parallel switched by relays or similar.
As an alternative, use a motarized varicap.
These are sold all over the internet. Ignore the volume control circuitry and use a shaft coupler to put on your varicap.
https://www.ebay.com/itm/9V-Infrared-Re ... SwjXNbESAy
