It is currently Oct Fri 18, 2019 10:55 pm
 Post subject: QST two tube superhet
PostPosted: May Tue 14, 2019 2:07 am
Hello all,
I am back once again with another question. Two years ago I started building this two tube superhet. It uses a 6K8 and 6C8. I never finished it and now I want to complete the build. The problem is I still have the schematic diagram but I lost the notes on the build, and I am no longer a member of ARRL, so I have lost access to the QST archive. Does anyone know of the circuit I am referring to, or have access to QST?
Tnx,
Robert
 Post subject: Re: QST two tube superhet
PostPosted: May Tue 14, 2019 3:06 am
In my very incomplete index I have the following entries:
The Novice Special (two tubes), QST, June 1956 page 34
Selectivity With the 2-Tube Regenerative Receiver (use a short antenna), QST, January 1939 p 36. As I remember, this one used 2.5 V tubes but I might be wrong.
Here is a web site that has older QSTs: http://www.rsp-italy.it/Electronics/Magazines/QST/
Good luck. If you find it tell us where.
Jim Mueller
PostPosted: May Tue 14, 2019 3:47 am
Jim,
Thank you very much. I found it in the February 1941 issue, page 12.
PostPosted: May Tue 14, 2019 5:19 am
It also appeared in the ARRL Handbook for several years.
PostPosted: May Tue 14, 2019 3:26 pm
I have another question. On my website http://www.kg4kgl.net, is a pair of circuit diagrams. I started building the first one. The second is from the Feb 1941 QST article. It has been two years and I am not sure where I got the first article. They are different. The QST article uses the triode of the 6K8 as an LO. Would the first circuit even work?
PostPosted: May Tue 14, 2019 3:51 pm
Yes, it appears to just be a different way of drawing the 6K8, in reality what they are showing as G2 on the tube is the triode plate.
That tube drawing more closely resembles a 6A8 or 6A7 than it does a 6K8 but if you understand the internal construction of the 6K8, it seems the circuit would oscillate.
PostPosted: May Tue 14, 2019 5:45 pm
Well I am comparing the two diagrams and the work that I have done so far, and it seems I do not need to undo anything. So I will just continue building it with the QST supplied schematic diagram.
PostPosted: May Tue 14, 2019 11:16 pm
Robert,
This sounds like a really fun project.
Would you mind posting with images along the way?
Minimalist radios fascinate me.
Chas
PostPosted: May Wed 15, 2019 2:03 am
Will do, but don’t expect much in the way of metal work. That is not my strong suit. :roll:
PostPosted: May Wed 15, 2019 7:41 am
Here's a link to the one that Exray built:
http://www.sparkbench.com/homebrew/grammar/grammar.html
PostPosted: May Fri 17, 2019 7:59 pm
I built it about a decade ago. A worthwhile project. Later, after finding an on-line article by W0VLZ about adding a third tube, I did that, too. Made it even better! In fact, he posted two articles: https://www.prismnet.com/~nielw/3tubrcvr/3tubrcvr.htm and https://www.prismnet.com/~nielw/3tube_xtal/3tube_xtal.htm. Pictures, schematics and parts list included.
If you find the metalworking a challenge, you could build it on a simple sheet of stout aluminum about 6 x 8", say 0.08" or 0.09" thick, and use wood for side supports. Here's mine:
PostPosted: May Fri 24, 2019 12:07 am
Very nice!
BR,
Terry
PostPosted: May Wed 29, 2019 10:52 pm
The 1/39 QST article does use the old skool 2.5v standard base tubes. The direct replacement would be 6D6 for the 58 and a 76 or 37 for the 56. The more modern self centering tubes would be the 6SK7 and 6J5 or 6C5. Fred Sutter the author was the guy that designed the famous QSL 40 transmitter series.
GL
The other Terry
PostPosted: Jun Thu 06, 2019 1:14 pm
I have pored thru alot of old QST mags and drooled over some of the cool vintage projects. Then, flipping thru the magazine for a couple months later, read "In such and such article, resistor R12 should be 1000 Ohms, not 1 meg Ohm, and C11 is missing...".
I therefore consider maybe the handbook projects might be more trustworthy, as presumably they were debugged before being added. Having a sampling, not every issue, of old ARRL handbooks is nicer than the tons of magazines. Then having access to the online archives is nice if you know where to look.
PostPosted: Jun Sat 08, 2019 1:22 pm
I don’t know if it’s still in print, but QST published a collection of receiver projects from previous magazine articles. Worth a look.
