It is currently Aug Sat 17, 2019 6:08 pm
Post New Topic Post Reply  [ 288 posts ]  Go to page 1, 2, 3, 4, 5 ... 15  Next
 Post subject: Another Little Prince- tube preamp
PostPosted: Mar Fri 08, 2019 12:02 am
Another Little Prince. The Little Prince is a control amp and was built to be a preamp for the Prince John. I am John, the builder of the amps.
But not at all the designer. Flip presenter the modified schematics.
Thanks to him, Peter, and others, I have so much fun building and learning.
This amp will control my 807 Williamson. Thanks much to Flip.
The original Little Prince uses the 20EZ7 tube X six. It controls volume, balance, bass, and treble. Has RIAA amp. A selectable input
switch for phono/mp3/cd.
I wanted this amp to use six 12SL7 Octal tubes to match the 807's.
Should be fun.
Here is the 807 Williamson.
http://antiqueradios.com/forums/viewtop ... 2&t=338702
http://antiqueradios.com/forums/downloa ... ?id=163072
http://antiqueradios.com/forums/downloa ... ?id=163998
The power supply.
http://antiqueradios.com/forums/downloa ... ?id=246310
The new RIAA amp
download/file.php?id=254025
The new tone amp
download/file.php?id=246313
John Smith, over and out.
 Post subject: Re: Another Little Prince- tube preamp
PostPosted: Mar Fri 08, 2019 4:56 am
The power transformer will be Edcor XPWR 218-120. It has two 120volt 50ma windings, and one 12volt 1amp.
The six 12SL7's need 900ma at 12volts.
Here is the basic high voltage supply. The filter and ballast resistor need to be figured. Aiming for about 250volts.
download/file.php?id=246113
PostPosted: Mar Fri 08, 2019 5:10 am
You don't need to multiply the secondary when you have two of them. Just put them in series and use a full wave bridge. E.g. it's a 240VAC CT with the center tap unused.
PostPosted: Mar Fri 08, 2019 5:40 am
That's a better idea. I guess 50ma is plenty of power? Do you suggest a full wave rectifier?
What do you figure the total full load B+ current will be?
PostPosted: Mar Fri 08, 2019 5:42 am
Flip-
Could the 250k volume pots be replaced with 100k?
https://www.ebay.com/itm/9V-Infrared-Re ... SwjXNbESAy
PostPosted: Mar Fri 08, 2019 6:00 am
Here is the original Little Prince on top. And the 807 Williamson on the bottom.
The sound is spectacular.
download/file.php?id=245416
BTW- I reconstructed an old ammo case for the stereo cabinet. It had 'four' handles, and 12 places
for big shells. And, had a very old OD paint job.
PostPosted: Mar Fri 08, 2019 6:04 am
Yes, a full wave bridge is the most efficient. Current consumption is shown on the original Little Prince power supply schematic, about 15mA (14.4 mA rounded up). I'd up it a bit since we don't know what B+ actually is yet, say 20mA. Then times 1.8 (full wave bridge factor) = 36 mA to the transformer. That leaves 14mA spare (7.8 mA to the circuit).
PostPosted: Mar Fri 08, 2019 6:46 am
So would I figure a resistor based on the actual voltage minus 250volts at 15ma?
PostPosted: Mar Fri 08, 2019 6:57 am
Figure on increasing R1 and R4 (equally) based on 15mA. E.g. both at 1k would drop 30V and both at 2.2k would drop 66V, which I think would be about right. Minimum 1W resistors.
Filter caps C3 and C5 can be reduced proportionally to 62uF, say 100 uF for a little better filtering. C8 would remain at 470 uf. In actuality, they could all be reduced but it would take more work to figure out the ripple.
Revised. I checked the sim and, with C3 and C5 at 100 uF and R1 and R4 2.2k, C8 can be lowered to 220 uF. That produced essentially the same ripple as the existing Little Prince so assuming it's hum free that would be hum free in the new one.
PostPosted: Mar Fri 08, 2019 10:21 pm
RIAA section schematic.
Volume-Balance-Tone Control section schematic.
12SL7 Baxandall Tone Control w-Vol-Bal v3 - as built.jpg [ 125.82 KiB | Viewed 1314 times ]
Edit: Added missing D1 to Phono Preamp.
PostPosted: Mar Fri 08, 2019 11:04 pm
Thank you Sir.
I will figure on the changes. Here is the original power supply. Quite different from the new one.
download/file.php?id=165323
PostPosted: Mar Fri 08, 2019 11:53 pm
Here is a draft of the new Power Supply. May need changes as we go.
PostPosted: Mar Sat 09, 2019 5:41 am
The attachment new ps.jpg is no longer available
You got it. Here's my schematic.
Edit: changed R3 from 500 to 2K.
PostPosted: Mar Sat 09, 2019 5:47 am
Note, that 12V winding is 12V, not the heaters 12.6V. But I don't think being 5% low is going to hurt anything.
PostPosted: Mar Sat 09, 2019 5:55 am
I was thinking about that. And noticed on some preamp tube filaments a lower voltage is used. Like a resistor in series.
As long as you think it will work, then its a go.
I wonder why that winding was not 12.6v.
PostPosted: Mar Sat 09, 2019 5:58 am
Thanks for the power supply schematic. I like your better. And think I have all the components already.
PostPosted: Mar Sat 09, 2019 6:09 am
Is this still a good idea, for the MP3 booster.
PostPosted: Mar Sat 09, 2019 6:49 am
Don't know but likely it wasn't meant for heaters, rather some solid state supply or something.
The only thing that concerns me a bit is in this one the heaters are AC whereas the first Little Prince eliminated any chance of hum with it's DC heater supply. I note the Shure tube phone RIAA amp had AC heaters too but it was 6.3VAC and ours is double that. We may need to bias the heater supply up to some voltage. I need to think on that some more.
PostPosted: Mar Sat 09, 2019 6:50 am
Ah, there it is. I couldn't find that schematic at first but it was right there all along.
Yes, it should still work.
PostPosted: Mar Sat 09, 2019 7:12 am
Good. I will use it. Thanks for that.
Looks like some fancy switching will be needed.
Users browsing this forum: infzqi and 2 guests
