It is currently Jul Wed 15, 2020 6:20 am
 Post subject: Unreliable Output - Field Strength Meter
PostPosted: Dec Mon 23, 2019 6:05 am
I figured out how to get my field strength circuit working (https://www.airplanesandrockets.com/ele ... 54-man.htm) but I am dealing with very WEAK transmitted signals. As such, I added an amplifier stage to the original circuit.
The new diagram looks like this:
I have a very odd issue, where the set occasionally works extremely well. It will show a 1-1.5 mA dip on the meter, and clear audible signal in the headphones. Then, for no reason, it becomes very quiet, showing dips of no more than a tenth of a mA, for the same signal. The set is sitting perfectly still- No jostling or movement. The power supply for 45 V is steady, and it's not an issue with the D cell powering the filaments.
The set amplifies a sound signal extremely well, never showing this issue. To add a sound signal, I place my input on the intersection of the 330 pF grid capacitor and the 1M grid bias resistor on grid 1 of the first tube, and ground the other end of the audio signal. The meter will show dips up to 2.5 mA. Touching the intersection with a finger produces a very loud hum, and the meter drops to zero (as expected).
Because of this, I am guessing my issue is related to the LC combination and/or the 330 pF capacitor. None of these components are faulty, and I can't figure out why in the world the signal would occasionally be excellent then suddenly, and for no apparent reason, drop so drastically. The set normally operates on that subpar level.
A little backstory: I am trying to get relative readings of transmissions on frequencies from 800 MHz to 5 GHz (typical cell phone and wifi technology). The coil would be tuned for way down at 30 MHz, but I am hoping that it instead acts as a choke for higher frequencies while letting most RF pass through to ground. Without the variable capacitor, I can hear the signals, but with the same problem described above. Adding the capacitor and cranking it to highest capacitance gave a slightly stronger signal reading in my test set. Once assembled on the board, however, it seems to make no difference (and I still hear the transmissions the same).
Here are images of the set as it is right now. The brass strip is the common ground, which the voltage supply negatives are connected to, as well as the bottom of the LC circuit.
As you can see here (with no signal) the 5000 ohm resistor almost perfectly centers the I-70 5 mA meter. The I-70 is a typical ammeter, with the distinction of no values being printed on the dial. It also is at zero to the right, not the left as most meters are. This way, when you are tuned to maximum signal, the needle is furthest to the right ("highest" signal reading, but lowest current).
-Eli
http://www.FortCollinsB17.org
 Post subject: Re: Unreliable Output - Field Strength Meter
PostPosted: Dec Mon 23, 2019 6:39 pm
I haven't gotten that far yet- I can't get the meter to show any output, even when I add a strong signal to the grid.
If your input circuit is tuned to 27 MHz, you won't get much result at 1000 KHz.
PostPosted: Dec Mon 23, 2019 6:43 pm
Hi Rich,
That whole issue was resolved by having a higher plate voltage. It's also important to note that my test signal is past the tuned circuit, added directly to grid 1, and not on an RF frequency.
-Eli
PostPosted: Dec Mon 23, 2019 8:48 pm
I am not sure how that last stage works as a detector and meter driver. One would expect
to see a RF amplifier, followed by a detector to demodulate the audio and drive the DC meter.
Odd circuit.
Pete
PostPosted: Dec Mon 23, 2019 9:21 pm
Odd circuit.
Pete
My hope is that the first tube still acts as the detector. The second tube just amplifies the output signal for a louder volume in the headphones, and stronger meter dips.
-Eli
PostPosted: Dec Tue 24, 2019 12:31 am
Interesting update:
I can remove the LC circuit and still have the same reception. I replace it with a straight wire to ground- The antenna is then connected to ground. What in the world??
-Eli
PostPosted: Dec Tue 24, 2019 7:03 pm
Not surprising.
L/C wasn't tuning anything of interest in the first place.
PostPosted: Dec Tue 24, 2019 11:09 pm
My reliability issue was due to the first tube. Something was wrong with it internally. I replaced it and now have no issues.
Perhaps someone can explain this to me, though... If I stretch the antenna a certain direction, I pick up an FM station! 96 MHz. I'm not too surprised to hear a signal at that frequency, but I am surprised it's an FM broadcast station.
-Eli
