Page 1 of 1
[ 13 posts ] |
Author |
jimbob
Post subject: Spider coil forms Posted: Sep Mon 06, 2021 1:20 am |
Does anyone know where spider coil forms can be found? I know pebbles used to sell them,but I understand they are no longer taking orders. If I have to make my own what materials can I use? Does it have to be plastic or could I use thin plywood or cardboard?
Top |
mrx
Post subject: Re: Spider coil forms Posted: Sep Mon 06, 2021 1:46 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4179 Location: Boston, Massachusetts
would have to be rigid, plastic, bakelite, masonite, phenolic, CDROM, etc... Crosley and others used cardboard, although I think you would have to impregnate it to make it stable and rigid.
_________________ Andrew
Top |
Macrohenry
Post subject: Re: Spider coil forms Posted: Sep Mon 06, 2021 4:27 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5576 Location: Texas
Is this for crystal radio? If so you want to minimize your losses. High Density Polyethylene (HDPE) has less loss than just about any other material. For example, cardboard (paper) has a dielectric constant of 3.7 while polyethylene is 2.25.
Does anyone in your family have cats? Cat litter containers produce sheets of it big enough for a spider coil. The 40 lb containers are rigid enough to be used single ply. The 20 lb containers may need to be doubled or tripled up.
Also you can use a corrugated election or garage sale sign. Harder to cut cleanly, though.
Top |
mrx
Post subject: Re: Spider coil forms Posted: Sep Mon 06, 2021 4:55 am |
Top |
jimbob
Post subject: Re: Spider coil forms Posted: Sep Mon 06, 2021 3:23 pm |
Thanks for the suggestions guys,I'll probably use Masonite . I use it all the time for radio chassis and panels.
Top |
krystallo
Post subject: Re: Spider coil forms Posted: Sep Mon 06, 2021 4:04 pm |
Joined: Jul Thu 12, 2007 9:36 am Posts: 668 Location: Boston,Ma
Hey Jimbob, Masonite used as a coil form may be fairly lossy. On a good antenna /ground , it "should" work on local strong stations. If you are going for any type of Dx, I might shy away from Masonite and go with a formless basket weave or other type of coil. Will you actually NOTICE and HEAR a big degrade with Masonite forms- "maybe". FWIW, ie with the Crosley Model 50, the coils are wound on wooden dowel "spokes" that radiate from a center hub.You'll notice that the wire has a somewhat restricted direct contact with the dowels. There is a lot of AIR in the coil ( a good thing  ). IMHO- In ANY type of coil form : the less coil form /wire contact , the better. In a crystal set (if that's what you're building) EVERY theoretical loss should be minimized. Multiple sources of loss within the "stages" can add up ( ie type of coil form used, det/tank Z match, det phone Z match, etc, etc, etc.). In an amplified set, particularly one that has RF amplification, it might not be so critical. So it depends. I sometimes intentionally use "less than optimal" techniques for construction convenience or simply for looks. K
Top |
Mike Toon
Post subject: Re: Spider coil forms Posted: Sep Tue 07, 2021 7:03 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6482 Location: Beautiful Downtown Burbank CA
I have used the plastic CD "protectors" and cut them on the bandsaw. Even used a butter lid to prove it can be done.
Attachments: |
Top |
NW2K
Post subject: Re: Spider coil forms Posted: Sep Tue 07, 2021 11:06 am |
Joined: Jan Fri 27, 2017 8:41 pm Posts: 468 Location: Springwater, NY
Here is a link to what is used in the Antique Wireless Association's Radio Fab Lab, which is an excellent hands-on program for ages 8-15. The coil forms are laser cut in acrylic or polycarbonate...no attempt is made to reduce RF losses. http://awa.canadice.net/AWA's Radio Fab Lab is getting ready to start with several new classes for area youth, which include an Introduction to Analog and Digital Computers and Build an AM/FM Radio. 73 Dean
Top |
err ducks
Post subject: Re: Spider coil forms Posted: Sep Wed 08, 2021 12:46 am |
Member |
Joined: Mar Wed 26, 2008 3:06 pm Posts: 866 Location: Cave Springs, AR
I always wanted to try tinker toys. The only drawback is that they only have an even number of spokes. An odd number would help with stray capacitance.
_________________ Mark
Top |
krystallo
Post subject: Re: Spider coil forms Posted: Sep Wed 08, 2021 6:24 pm |
Hey Mark,
GREAT to see you in here. It's been a LONG time !!!
I too was thinking Tinker Toy for reproducing a Crosley type coil. I forgot how many spokes it had though.
One could drill press out a section of a wood and glue in very small radial dowels (I suppose ). Personally I usually go 13 point basket weave formless and call it a day .
de N1NQC
Top |
COM-NAV-ECM
Post subject: Re: Spider coil forms Posted: Sep Sat 18, 2021 9:12 am |
Member |
How about plexiglass or lexan? Micarta? Where can I look up their dialectric characteristics? Thanks
_________________ 1970's Avionics Tech, USN Attack Squadron 147, "ARGONAUTS" A-7E A/C
Top |
KB4QAA
Post subject: Re: Spider coil forms Posted: Sep Sat 18, 2021 6:16 pm |
Joined: Feb Wed 12, 2014 4:25 pm Posts: 322 Location: Southeast Kans. - KA0HCP
Top |
COM-NAV-ECM
Post subject: Re: Spider coil forms Posted: Sep Sun 19, 2021 10:48 am |
Member |
KB4QAA wrote: COM-NAV-ECM wrote: How about plexiglass or lexan? Micarta? Where can I look up their dialectric characteristics? Thanks Extensive list of Dielectric Constants. https://www.clippercontrols.com/pages/D ... alues.htmlThank you very much!
Top |
Page 1 of 1
[ 13 posts ] |
Users browsing this forum: No registered users and 14 guests |
