It is currently Nov Sat 27, 2021 4:09 am
 Post subject: 2n2219A based 2m ham band amplifier
PostPosted: Sep Sat 18, 2021 6:05 pm
Here's another amp for 144-148MHz... I've noticed that sometimes real life gain is 2dB lower than LtSpice but still one should get a solid 0.5W out on 2 meters with 50mW of input power from this amplifier for you to connect to your local repeater or just have simplex fun. LtSpice showing a solid 0.9W and if the construction is just right then it should be achievable. The linearity is just enough for use in a 2m ssb transceiver, the 680 resistor in final may have to be increased by a few ohms for that.
 Post subject: Re: 2n2219A based 2m ham band amplifier
PostPosted: Sep Sat 18, 2021 6:59 pm
If it's for FM, might as well go class C. And most have FM rigs that put out more power
PostPosted: Sep Sat 18, 2021 8:12 pm
Class C would give lower gain. SSB is still popular on 2 meters. It was designed for a ham. Building your own equipment is fun! I'm just letting everyone know that transistors like 2n2219A are useful in the VHF region! Impressive, isn't it?
PostPosted: Sep Sat 18, 2021 8:54 pm
Haha yes. Are such circuits like I posted above are of any use today? Homebrewing is a different kind of addiction.
PostPosted: Sep Fri 24, 2021 11:34 am
Right you are!
https://nandustips.blogspot.com
Users browsing this forum: Google [Bot], Jim Mueller and 9 guests
