It is currently Sep Fri 30, 2022 8:17 pm
 Post subject: Winding Antenna Coils
PostPosted: Jun Mon 20, 2022 10:43 pm
Looking for best practice tips on winning these. Should the antenna winding be below the grid winding on the coil form? Also does it matter if the antenna side or ground side is closest to the grid coil?
I know they need to be wound in the same direction but haven't read any more tips other than that.
Attached is a schematic I am interested in building
 Post subject: Re: Winding Antenna Coils
PostPosted: Jun Tue 21, 2022 3:48 pm
Not knowing what your circuit might be, here are some suggestions:
https://antiqueradios.com/forums/viewtopic.php?f=12&t=377080&view=next
The "Ocean Hopper" kit was a popular starter radio and if you search, you can find some useful data.
PS: I can't find WA6VVL's excellent page of Ocean Hopper coil-winding data in a full-size JPG. Anyone have a link?
PostPosted: Jun Tue 21, 2022 4:46 pm
I found the coil data on an old hard drive.
Hopefully, this will now be available on ARF for a few months.
PostPosted: Jun Tue 21, 2022 6:16 pm
My understanding is that the antenna winding is placed at the ground end of the grid winding to minimize capacitive coupling between the windings. The phasing between the two windings doesn't matter, AFAIK, so either the ground wire or the antenna wire could nearest the grid winding.
PostPosted: Jun Tue 21, 2022 7:00 pm
If it's a regenerative circuit, the phasing is important on the tickler vs. grid. Antenna can be either way.
PostPosted: Jun Mon 27, 2022 6:14 pm
You may want to consider winding them on separate forms. Variable coupling is sometimes a nice thing to have.
Mark
Users browsing this forum: Alfredo_T and 19 guests
