It is currently Sep Fri 30, 2022 7:02 pm
 Post subject: 455KHz IF oscillator with only three parts
PostPosted: May Sat 14, 2022 7:06 pm
Anybody willing to test this circuit? I don't have a three pin ceramic resonator.
 Post subject: Re: 455KHz IF oscillator with only three parts
PostPosted: May Sat 14, 2022 8:34 pm
Where did you get this? I suspect that I'm the inventor of that circuit. I came up with it on my own and I've never seen it anywhere else on the web. Here's my original published version.
http://www.tompolk.com/inventions/455_K ... lator.html
Really curious where you got it.
It works. Battery voltage is critical and variable with each sample of device.
PostPosted: May Sat 14, 2022 9:30 pm
Is that so? Wow, cool! A friend of mine send me the same schematic in mail. It wasn't downloading to my phone so I had to redraw it.
PostPosted: May Sat 14, 2022 9:35 pm
On a side note, are you a programmer as well? I'm talking about microcontrollers and HEX codes, a PIC series microcontroller is going to drive a CD4046 + LCD + take inputs from four keys to cover the 87.5-108 MHz band in 100KHz steps. A obsolete dedicated PLL chip like TSA5511 isn't needed then. The microcontroller is directly able to control CD4046.
PostPosted: May Sat 14, 2022 10:27 pm
I could call myself a programmer if I could call myself a brain surgeon. I can program a VCR and adapt Arduino code to my purposes, but starting from scratch? Nopers.
PostPosted: Jun Tue 14, 2022 9:36 am
You could use a 432Kcps xtal in series with a 30p cap to tune the tx above and below 455.
This for the reception of usb , lsb , cw .
maxeq
PostPosted: Jun Thu 23, 2022 1:01 pm
The main idea was published in the British mag. "Electronics World" in 2001, Sept.
PostPosted: Jun Thu 23, 2022 4:22 pm
could it work , something like this?
Users browsing this forum: No registered users and 16 guests
