Laser cut form for spider coil
Ads are not permitted.
Post Reply
black85vette
Aug Sun 02, 2015 6:34 pm
Yukon, OK
Contact:
Post by black85vette »
Found another use for my laser. Used 3mm acrylic and designed a 7 segment form with a 1.5 inch inner diameter. Form is about 8 inch in diameter. Using 26 ga wire, I used up all that was left on a spool and it came out to 536 uh. I can easily change any measurement or number of segments. It is also easy to include holes for mounting or securing the ends. Takes around 10 min for the laser to do the cutting. Should be useful on some of my regen builds.
Rick
AB5ON
Forest Gumping through life
N2LXM
Jan Thu 01, 1970 12:00 am
Wayside, NJ
Re: Laser cut form for spider coil
Post by N2LXM »
Beautiful work.
black85vette
Yukon, OK
Contact:
I liked the results so I made a form for another project. I decided to try 3mm plywood and a much smaller diameter that included a mount. Sets at 300 uH.
Rick
AB5ON
Mike Toon
Burbank CA
Post by Mike Toon »
Sure looks easier than my band saw and plastic.
You must be register and login to post a reply.
Post Reply
