1626, VT-137 triode, anyone homebrew this tube?
Ads are not permitted.
Post Reply
War Bird Radio
Jan Thu 01, 1970 12:00 am
Amarillo, TX
Post by War Bird Radio »
Just curious if anyone has used the 1626 in any homebrew projects?
Tube data http://www.r-type.org/pdfs/1626.pdf" -="window.open(this.href);return false;
I picked up 21 NOS 1626 Hytron tubes at a swap meet earlier this year for next to nothing.
All still boxed and dated 1943 and 1944.
Here's a couple out of the bunch.
hwhall
Jan Sat 25, 2020 4:23 am
Colorado Springs, CO 80917
Re: 1626, VT-137 triode, anyone homebrew this tube?
Post by hwhall »
Oscillator tube in the WWII Command set transmitters.
I wouldn't mind having a couple, or even just boxes, for a museum scene.
Mr. Detrola
Detroit, Michigan, USA
Contact:
Post by Mr. Detrola »
If you have a ham license it would make a fun QRP transmitter build.
Not very much gain, so not very useful as an audio amplifier or as an audio output stage, although you could probably coax half a watt out of it or maybe close to a watt with 2 of them in P-P.
It's a tube which Heathkit and perhaps others would have used in unconventional applications back in the day when they were available by what seemed like the millions for next to nothing. As one example, Heath used it as a rectifier in test equipment.
War Bird Radio
Amarillo, TX
Dennis,
I like the idea of a P-P TX. Might have to throw something together ala Frank Jones.
I think Heathkit also used two 1626s in the K2 All Band Receiver, one for detector and one rectifier.
Maybe a two step regen using 1626s as both detector and AF to go with the P-P TX!
Edited to correct typo.
Last edited by War Bird Radio on Oct Sun 29, 2023 3:40 pm, edited 1 time in total.
hwhall
Post by hwhall »
I think Heathkit also used two 1625s in the K2 All Band Receiver, one for detector and one rectifier.
Maybe a two step regen using 1625s as both detector and AF to go with the P-P TX!
You meant 1626. 1625s would be really "impressive" in a regen!!! :shock: :D
War Bird Radio
Amarillo, TX
Error noted and corrected. Thanks!
But a 1625 or 807 regen is very doable. There's a guy on ebay and Etsy selling such regns for a number of years now.
https://www.etsy.com/listing/1021539791 ... e_21&frs=1" -="window.open(this.href);return false;
hwhall
Post by hwhall »
Madness, I say! Sheer madness!! :wink:
shinkuukan
Dec Sun 14, 2008 2:33 pm
TOKYO JAPAN
Post by shinkuukan »
From just eyeballing the RCA curves, it seems the 1626 has an Rp of about 3K, Gm about 1700 mmho. That is, at typical high plate voltages. At low plate voltages, which you would need for a regen detector, the Rp would probably fall to maybe 2K (or less), mu staying about the same 5, Gm rising to 3000~4000 mmho. Hard to be more precise, the curves are too coarse at low plate voltage and current. Still, it would make a fine regenerative detector, not much audio gain, but very smooth regeneration control. Expect B+ around 15~20VDC. If you figure the realistic audio gain of a 1626 to be about 3, you'd need at least two of them to give you adequate high Z headphone volume. Most important, a three or four 1626 radio would really look the part.
Rob
Sal Brisindi
Freehold, New Jersey 07728
Contact:
Post by Sal Brisindi »
I built a nice 3/4 watt stereo amplifier with the 1626 tubes. Sounds amazing with high efficient speakers... do a search on the Darling amplifier. To see the amp I built, click https://www.audioasylum.com/messages/tu ... arling-amp" -="window.open(this.href);return false;
Sal
Need capacitors, resistors and other parts--> http://www.tuberadios.com/capacitors
Mike Toon
Burbank CA
Post by Mike Toon »
Very neat construction. Good going.
War Bird Radio
Amarillo, TX
Sal,
I've seen the Darling amp and it seems to be a lot of work & expense for a low power amp.
I built a 6T9 stereo a while back that was 4 watts per channel. The only thing I bought for the project was the output transformers, everything else I had in the 'ol junk box.
I prefer something RF wise with these tube, like receiver and or CW transmitter.
Frank Jones's Push-Pull CW transmitter is pretty simple and performs well. I've built it using the #53, 6A6 and 6N7 tubes and each had 10 watts out on 80 & 40 mts. Even a 6SL7 will put out 5 watts. Anyway, I'm curious what a pair of 1626 would do. I'll bet more than a couple watts.
Sal Brisindi
Contact:
Mike Toon wrote:Very neat construction. Good going.
Thanks!
Sal Brisindi
Contact:
War Bird Radio wrote:Sal,
I know, I was curious how it sounded. I built 2 of them and sold one of them to a very happy customer.
Sal.
PS, I gathered up most of the parts to build the 6T9 tube amp but I never got to it.
ACORNVALVE
Jan Wed 15, 2020 11:29 pm
Queensland, AU
Post by ACORNVALVE »
The 1626 appears similar in its physical proportions and power ratings to half a 6N7 double triode. Though the Class C specs are not that helpful comparing the two, but they are basically both 5 Watt triodes although the 1626 has a low amplification factor.
The 6N7 has been used in a number of audio amp circuits over many years, you could use two of these tubes in its place, with the correct heater voltage of course and probably some bias adjustment.
err ducks
Mar Wed 26, 2008 2:06 pm
Cave Springs AR
Post by err ducks »
One 1625 Regen coming up! (12V Space charge, 2 band SW, cathode tap.)
Mark
N0BST
Cambridge MN
Post by N0BST »
Talk about using a sledgehammer to kill a gnat! Love it.
Scott Todd
You must be register and login to post a reply.
Post Reply
