Interested in LowFER
Ads are not permitted.
Post Reply
arianskre
Dec Wed 22, 2021 7:20 pm
Sherwood Park, Alberta
Post by arianskre »
Has anyone played around in the 1750 meter band? I discovered it not too long ago and it peaked my interest. I would like to know if this is something worth getting invested in or should I get my radio kicks elsewhere? :lol:
stevebyan
May Wed 18, 2011 1:40 am
Littleton, MA
Contact:
Re: Interested in LowFER
Post by stevebyan »
arianskre wrote:I discovered it not too long ago and it peaked my interest.
Sorry can’t offer any insight into the Lowfer ham band, but I’ll be the grammar nazi: piqued, not peaked.
arianskre
Post by arianskre »
Stevebyan, the grammar correction is appreciated! I did not know it’s spelled piqued. Well heck, I learned something so far :D
Chas
Jan Thu 01, 1970 12:00 am
S. Dartmouth MA USA
Post by Chas »
http://www.arrl.org/lf-low-frequency" -="window.open(this.href);return false;
Pliny the younger
“nihil novum nihil varium nihil quod non semel spectasse sufficiat”
arianskre
Post by arianskre »
So far I’ve only read information regarding FCC regulations in the US. What about Canada? I checked the frequency allocation chart provided by Industry Canada and all it says is “160KCs-190KCs FIXED”. I don’t think I want to get on Industry Canadas bad side by sending some code at a forestry service or something like that.
Rich, W3HWJ
May Tue 30, 2006 3:46 pm
Santa Rosa, CA
Contact:
Post by Rich, W3HWJ »
Band allocations for Canada, including Low Freq. bands:
https://www.rac.ca/rac-0-30-mhz-band-plan/
chipveres
Oct Tue 31, 2023 12:33 am
Hollywood FL
Post by chipveres »
Please note that 136 KHz and 160-190 KHz are two different bands with radically different regulations. I'm only familiar with US regulations but I think something similar pertains to Canada. On 160-190 you need no license, but are limited to 1 watt transmitter input power and a 50 foot antenna. On 136 KHz, licensed hams (only) can run 1 watt ERP. That's a huge difference because of the low efficiency of amateur antennas at longwave.
73 Chip KM4SJN
popularplanarlabs.blogspot.com
Macrohenry
Austin TX
Post by Macrohenry »
A few years back I heard a beacon on my Lowfer radio. I tracked it down to an aviation beacon not far from the Austin airport. I was surprised that they still use that technology. The antenna was a wire suspended between two masts more than 100 feet apart.
It's hard to be simultaneously curious and annoyed
Rich, W3HWJ
Santa Rosa, CA
Contact:
Haven't listened in a while, but Low Freq. MCW (modulated Morse Code) beacons were pretty standard. NDB = non-directional beacon
https://www.dxinfocentre.com/ndb.htm
allthumbs
Aug Wed 25, 2010 2:23 pm
Tacoma, WA 98407
Post by allthumbs »
I was tempted to make the same comment. But I exercised self-restraint...then I saw stevebyan's reply and decided to pile on. :D
BobWeaver
Saskatoon, Canada
Contact:
Post by BobWeaver »
Rich, W3HWJ wrote:Haven't listened in a while, but Low Freq. MCW (modulated Morse Code) beacons were pretty standard. NDB = non-directional beacon
They've been shutting them down over the past few years, but I just checked, and the local ones here are still on the air.
Other things you can listen to if you go a lot lower in frequency is the VLF stuff such as WWVB at 60 kHz, and several US Navy stations at around 20kHz. I built a VLF up-converter for my SW radio, and a VLF loop antenna that works great at picking up these signals.
arianskre
Post by arianskre »
Doesn’t VLF use mostly earth-mode?
Rich, W3HWJ
Santa Rosa, CA
Contact:
Is "earth mode" another name for ground wave?
https://en.wikipedia.org/wiki/Ground_wave
arianskre
Post by arianskre »
Earth-mode is an archaic term for a ground dipole, my apologies. I’m also wrong in this case! ELF uses ground dipoles, VLF doesn’t.
Post Reply
